Model Aviation Magazine
  • Originally posted by MesRcPilot View Post
    Hello Rob , welcome onboard ,you are my neighbor (Kroatien) and in Austria I bought my Spit 1600 freewing . You got it all handy, and not expensive as in the NL warehouse.š.Also ,Here you will feel good because US modelers are eager to help their colleagues ... God Bless America, All the Best, Happy Christmas and New Year,Jos
    Note: https://www.d-m-t.at/flugzeuge/motor...1600-mm-detail ....But you already know that
    Hi neighbor from croatia
    this is the shop where i buyed the spitfire Dmt
    the other parts i buyed at motion rc eu
    Thanks all for the help
    also every one Happy new year and good flights
    regards from austria
    Rob
      Jos, Happy New Year, Sir. Great to see you are still working on your Spitfire. Post pictures as you are able. Best, LB
      Captain: Got any ideas?
      F/O: Actually not.
        Thanks so much Steve ....all life along I want to work on....and every time I watch gift favorite spit-cockpit I think of you ...All the best to your family
        • Originally posted by ryramZ View Post
          I'll have all the new planes I can fit in my van! If you guys don't leave me out of the Starbucks run I might even let you fly it...
          Hey Ryan
          Can you or someone else tell me if the waterslide decals provided with the Spitfire are hard to apply or just bad quality? I have built many of the Freewing planes including the A4 and I cannot work with the waterslides that are used in this kit. Everytime I try to move the decal from the paper backing (when wet) the decal breaks or pulls apart... totally unusable
          Ready to buy some from Callie Graphics
          Rich
          • Originally posted by RichJ53 View Post
            [T]he waterslide decals provided with the Spitfire I cannot work with the waterslides that are used in this kit. Every time I try to move the decal from the paper backing (when wet) the decal breaks or pulls apart... totally unusable. Ready to buy some from Callie. Rich
            RJ53, I had the same issue with the 'waterslides' and so I tried Micro Sol and Micro Set and it did not make a difference. Fortunately, I had gotten Callie's Spitfire Nomenclature set when she made my custom stuff. I'd save back the OEM waterslides and pick up the stickys from Callie. I did use the Roundel stickys from the kit and those worked okay. Best, LB
            F/O: Actually not.
            • Hello everyone! Thanks for the add. I am working on my spitfire by doing the cockpit upgrade with a warbirdspilot figure and I am modifying the rudder to a MK VIII type. The problem that I have is that after removing the canopy, I find that it has some kind of stains on it from the molding process. I also have a replacement canopy and when I opened it to check, it also has stains on it. Has anyone else had this problem and if so, what is the solution to clean the canopy. I have tried several types of plastic polish to no avail.
              • Broken Parts, Welcome to Hobby Squawk. I had a similar issue and I used a pink metal polish called 'Simichrome', It did not completely remove the vacuum molding marks, though it helped and also removed some of the acrylic paint that was poorly masked. All in all, I was happy with it. best, LB
                F/O: Actually not.
                  Hi LB
                  Yes I have used the Solvaset solution too, but the problem is you cant get the decal off the backing without damaging it. So, I think I will order some replacements from Callie. 1/7th scale size for this model.
                  thanks again
                  Rich
                  • Thanks Elbee, that helped alot. Here a couple of pictures of my cockpit.
                    • BP, Beautiful work on your cockpit. Best, LB
                      F/O: Actually not.
