Product page: https://www.motionrc.com/products/bl...342-2000mm-arf
The XtremeAir Sbach 342 (XA42) is a German high performance two-seat aerobatic and touring monoplane. The Sbach 342 is a composite structure low-wing monoplane with a fixed conventional landing gear with a tailwheel and carbon fiber fuselage.
The Black Horse Sbach 342 is lightweight yet durable with large, easy access hatches for your battery/fuel tank. With the recommended setup, the Sbach offers fantastic performance in an eye-catching livery sure to impress.
- High level of prefabrication right out of the box
- Lightweight, strong, and fully sheeted laser cut balsa and plywood construction
- Covered in high quality Oracover
- Recessed hinges on all control surfaces
- Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
- Painted and detailed cockpit, pilot and interior included
- Fiberglass twinned control horns with ball link connector
- Pull-Pull control system on the rudder for precision control and authority
- comprehensive control and fitting accessories included
- Two-piece, plug-in wings simplify transportation and assembly.
- Fiberglass cowl and landing gear covers/pants
- Mounts for both electric and gas power options included
- Fully illustrated instruction manual included and also available for download (see tab above)
- Black Horse Sbach 342 2000mm (78.74") Wingspan - ARF
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- 2300-3300 Watt Brushless Outrunner Motor - we recommend the Admiral GP26 6330-245kV Brushless Motor
- 85-120 Amp Brushless ESC - we recommend ZTW Gecko 120A ESC OPTO High Voltage Brushless ESC
- 8-18 Amp UBEC - we recommend ZTW 18A BEC / UBEC
- 5x standard servos - we recommend D930SW
- For 8S setup TWO 46 Cell 14.8V 5000 mAh LiPo Batteries with EC5 connector in series - we recommend TWO Admiral Pro 5000mAh 4S 14.8V 60C LiPo Batteries with EC5 Connector
- For 10S setup ONE 6 Cell 22.2V 5000 mAh and ONE 4 Cell 5000 mAh LiPo Batteries with EC5 connector in series - we recommend ONE Admiral Pro 5000mAh 4S 14.8V 60C LiPo Batteries with EC5 Connector AND ONE Admiral Pro 5000mAh 4S 14.8V 60C LiPo Battery with EC5 Connector
- 2 to 1 EC5 series adapter - we recommend Admiral EC5 2 to 1 Series Adapter
- Electric propeller 8S - we recommend the APC 19x10 Thin Electric Propeller
- Electric propeller 10S - we recommend the APC 17x10 Thin Electric Propeller
- 6 Cell compatible battery charger - select a minimum 6 cell (6S) charger from our Charger Collection
- Engine: 30 - 35cc 2-stroke, NGH GT35R recommended or 38-42cc 4-stroke, NGH GT38 recommended
- Gas Propeller: 18x10-20x8
