Product Page: https://www.motionrc.com/products/sk...ion-1120mm-pnp
Revolution 1120mm (44.1") Wingspan - PNP from Skynetic - SKY1034-001
Motion RC is proud to announce Skynetic, a new brand of foam electric aircraft for newer pilots looking to broaden their flying experience across a range of RC airplane types. Developed by and available exclusively at Motion RC, Skynetic advances our vision of a global audience discovering the fun of RC Flight. Backed by Motion RC's customer support and a full line of spare parts to keep you flying, join the Skynetic revolution!
The Skynetic Revolution is a 3D flyer that can penetrate through moderate winds while performing show-stopping 3D maneuvers with ease. Both wing and gear are easily removable for transport and/or flying preference. Made of light yet durable EPO foam with a streamlined and aerodynamic profile, the Revolution is tailor-made for countless hours of exhilarating, flying fun!
FEATURES:
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 1 HOUR
Easy To Transport The Skynetic Revolution is easy to transport with the quick disconnect wings and simple screw assembly. |
Intakes Provide Cooling The Skynetic Revolution has functional intakes to help with cooling. |
Large Control Surfaces The Revolution has oversized control surfaces, perfect for 3D and aerobatic performance. |
New Paint Scheme The Skynetic Revolution has an updated, sporty red and white paint scheme. |
Nylon Hinges The Revolution has nylon hinges for added strength and durability. |
Admiral ESC The ESC has been upgraded to an Admiral 40 amp. |
- Slick, streamlined and aerodynamic profile with sharp red, black and white livery
- Easy-to-remove wing and landing gear for transport and flying preference
- Powerful AS2814 KV1000 Brushless motor for a wide flight performance envelope
- Skynetic Revolution 1120mm (44.1") Wingspan - PNP
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 3 Cell 11.1V 1800 - 2200 mAh Li-Po Battery with XT60 connector - we recommend EPR18003X6
- 3 Cell compatible battery charger - select a minimum 3 cell (3S) charger from our Charger Collection
BUILD TIME : 1 HOUR
Wingspan | 44.1in / 1120mm |
Length | 44.29in / 1125mm |
Flying Weight | 890 - 920g |
CG (Center of Gravity) | Refer to the owner's manual |
Power System | Powerful AS2814 KV1000 Brushless motor (installed) |
Electronic Speed Control | 40-amp brushless ESC with XT60 connector (installed) |
Propeller / EDF | Electric propeller |
Servos | 4x 17g |
Landing Gear | Fixed |
Required Battery | 3 Cell 11.1V 1800 - 2200 mAh Li-Po battery with XT60 connector (required) |
Required Radio | 4+ channel radio system (required) |
Ailerons | Yes |
Elevator | Yes |
Rudder | Yes |
Flaps | No |
Lights | No |
Hinge Type | Foam |
Material | EPO Foam |
Skill Level | Intermediate |
Build Time | 1 Hour |
Recommended Environment | Outdoor |
