Official Skynetic 822mm Piaget II 3D Discussion Thread
  • Official Skynetic 822mm Piaget II 3D Discussion Thread
    Piaget II 3D 822mm (33.2") Wingspan - ARF BUNDLE from Skynetic - SKY1007-002
    Click here for the official product page
    The Skynetic Piaget II EPP is a fun, acrobatic performer made from the crash-resistant and easy to repair EPP foam. Cut your teeth on all the usual 3D maneuvers such as loops, rolls, knife edge, hover, hammer heads, flat spins and so on. Each flight is bound to give you several minutes of pure, unadulterated 3D excitement! Due to the durable EPP foam this plane is excellent for both beginners to 3D and advanced 3D pilots alike.
    FEATURES:
    • Designed with crash-resistant and easy to repair EPP foam
    • Specially designed for both slow, precise acrobatics and normal flight
    • Powerful AT2206 V2 Brushless motor for a wide flight performance envelope
    INCLUDES:
    • Skynetic Piaget II 3D 822mm (33.2") Wingspan - ARF BUNDLE
    • AT2206 V2 Brushless motor
    • 12 amp brushless ESC with JST connector
    • 3x 8g micro servos
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 5 HOURS
    Wingspan 33.2in / 844mm
    Length 36.2in / 920mm
    Flying Weight 210 - 230g
    CG (Center of Gravity) 75mm - 85mm from the leading edge of the wing at the root
    Power System Powerful AT2206 V2 Brushless motor (installed)
    Electronic Speed Control 12 amp brushless ESC with JST connector (installed)
    Propeller / EDF Electric propeller
    Servos 3x 8g micro servos
    Landing Gear Fixed
    Required Battery 2 Cell 7.4V 350 - 600 mAh Li-Po battery with JST connector (required)
    Required Radio 4+ channel radio system (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Foam
    Material EPP Foam
    Skill Level Intermediate
    Build Time 5 Hours
    Recommended Environment Indoor (outdoor under calm conditions only
    How would you mount a RX600 Motion RC receiver in this thing. On top of the wing at CG?
      I just ordered one of these, planning on using a modified flysky ia6 since I have one on the bench. it's modified to send pack voltage telemetry instead of receiver voltage. at any rate, I am hoping my 3d helicopter skills will transfer fairly well to 3d airplanes. My intent is to fly it in my yard, like my less than 250 gram helicopters.
        I forgot I used the modded fs IA6 in a heli, rather than remove it, I will be using a stock one. I assume the lvc is adjustable.. I guess I should have a look at the site and see if I can find setup parameters for it. my build is almost complete, hoping to maiden tomorrow. It was a mostly straight forward build, FYI, the sales site says jst battery connector, and an XT 60 was supplied. there are a few other variances, nothing too difficult to figure out, be prepared with a few sharp xacto blades for trimming, a small square was helpful, foam tac-rocks! getcha some!
          Thanks for posting your tips. Good luck with your maiden.
            Still no maiden... I discovered the 2s battery, 1500kv motor, and 9x4.7 prop won't lift it out of my hand in my house. it sounds wonderfully smooth, and all the electronics work, so now I will try with a 3s... which brings up the ESC issue... I got a 12Amp, marked Admiral, but I can't find any documentation on it (it came in the kit) Does the 12Amp program the same as the 10Amp listed in the Piaget II links?
