Originally posted by 406PIlot
View Post
What dual rates is everyone using for aileron, flaps, elevator and rudder? The manual is recommending the same high and low rate for aileron and elevator. Is this correct? I'm a little confused about the recommend flap setup. It appears there is only 1 setting for high and low rates for flaps. I can't find the recommended D/R for take off and landing flaps.
I would appreciate if someone is willing to share your setup.
The two Flap settings that are recommended starting points they have come up with during their testing of this plane. The Low rate is normally used as take off and the High rate is normally used for landings For your first flights. Then you can change them if you want more or less on both. Also they recommend mixing down elevator in with the flaps to keep it in level flight when the flaps are deployed. Here again this is just the recommended setting to start with. So I would start with their recommended throws. Then fine tune from there t for your own preference Every Pilot has their own settings and the planes will not all fly the same just to many variables evolved. Such as, your finale Aircraft weight, CG, Density altitude, elevation of flying site etc. You will love this plane I love flying mine, flies like a huge Trainer. So finish it and get out and have Fun
- 1 like
Have fun....consider adding the RF chokes for an added margin of safety.
If you will fly it a lot, consider reinforcing the top skin with carbon fiber inside the wing’s wiring channel as discussed in this forum. Avoid the top skin cracks like I got after a lot of flights. See photo below after 2,000 flights and aerobatics.
Search “ferrite”, “choke”, “RF choke” for info on these important items.
-GG
- 1 like
Thanks Wild Man & GliderGuy for feedback and recommendations. I think i'm ready to go.
I have a question about the neutral flap position. I have aligned the inner and outer flap w/ the leading edge of the aileron. I noticed the alignment causes an inward curve towards the fuselage which is causing a bit of a gap. Trimming up the inner and outer flap causes a misalignment. I hope this make sense. I have uploaded a few pics. Does this look right?
Thanks for posting a pic of your setup. I think I am good to go.
Simply line up the trailing edges all the way from the tip to the root, and you should be fine. Any gap that happens to show up is not an aerodynamic issue that far back on the wing anyway.
-GG
- 1 like
Originally posted by gentile View PostIs it possible to remove the graphics from the model with the Motion RC graphics already applied and replace them with Callie graphics. It looks like the biggest challenge might be the tail. The base white isn’t available and I’m ready to go!
Mike\"When Inverted Down Is Up And Up Is Expensive\"
