Model Aviation Magazine
Eflite Cherokee
  • BRGT350
    Operating mine off grass, I would be more than willing to buy an upgraded metal linkage for the nose gear. I added a servo saver to my nose gear and that should also extend the life of the nose gear linkage. The springs on the servo saver will allow the nose gear to turn either direction a few degrees and take some of the stress off the collar where the scissor linkage connects.
  • Hoomi
    Sent an email to Small Parts CNC, asking about the part. I don't see it on their webpage yet, but asked if it might be in work, or if they might consider making one.
    I wouldn't be surprised if a lot of the folks with this plane wouldn't mind dropping a few bucks on an upgrade part for the steering linkage.
  • Hoomi
    Thanks. Looking at many of the comments and reviews, if they made an aftermarket part out of metal, and kept the price reasonable, I'd bet they'd have a decent number of sales. I ordered two replacements directly from Horizon, figuring if the first one broke so easily, I'm not betting on the second one holding up for long, either. Yeah, the replacements are only $2.99, but that can add up if they need to be replaced frequently.
    It's worth contacting our friends at SmallPartsCNC, they create many aftermarket upgrade parts, and they're the only ones I can think of if you're looking for metal parts for parkflyers. They advertise on Hobby Squawk, but if you don't see their banner above, just navigate directly to their website, www.SmallPartsCNC.com
  • Hoomi
    I'm thinking of maybe taking some fine strip brass, and seeing if I can form it around the part of the steering collar right under the fuselage, to strengthen the joint without inhibiting it at all.
  • BRGT350
    I wouldn't count on an upgraded part. I don't think I have ever seen Horizon make an upgraded part, besides the nose gear on the A-10.
  • Hoomi
  • Hoomi
    Maiden flight this morning (played hookie from work, mostly due to not enough sleep last night). Definitely a lot more responsive than the Sensei. Successful flight, and while the landing wasn't the prettiest, came down without incident.
    Then, I had the front wheel catch on the ledge of the concrete slab for the club ramada, and snapped the steering linkage on the nose wheel. Looking at the Horizon Hobby page, the part is $2.99, but I'm reluctant to just replace a weak part with an identical weak part. Wondering if I can beef up the connection a bit to be more robust. I would love to see HH offer a beefier version of the part for those of us with less than ideal runways - maybe aluminum instead of brass?
  • BRGT350
    Hoomi, yes on the small notch being the stab alignment indicator.
  • Hoomi
    Mine arrived today. all assembled now, except for getting a receiver into it, which I may end up borrowing from Air Hooterville. If I get the Waco repaired before the receiver I ordered gets off back order, I can always reconnect the original Detrum receiver, and just haul the Detrum transmitter along to the flying field.
    Only issue I found in assembling, was that the control horn on the rudder was loose. The factory installed the push rod for the rudder with the metal part of the rod on top of the horn, which caused it to push down a lot more than I thought should be. I disconnected the push rod, reglued the horn, and once the glue was set well, reinserted the metal rod from below the horn. Seems a better arrangement, with less lateral pressure on the horn.
    I'm assuming the aforementioned horizontal stab alignment mark is the small notch on the right side of the fuselage at the leading edge of the stab?
    I haven't decided if I'm going to do any custom decoration on mine yet. I may just remove the stock numbers, order a custom number from Callie, and maybe have my wife make me some more Air Hooterville Flying Pig stickers.
    Of course, I'm still a bit tempted to do a complete repaint, and make it match the Cherokee I got to fly for the intro flying lessons a few years ago.
  • DzlDk
    Got mine home Saturday night and put together yesterday. Great looking plane!
    Too windy in KY yesterday to fly her though... Hopefully the rest of the week holds up.
  • BRGT350
    Originally posted by mrmat01 View Post
    Sorry to hear that you lost your Cherokee.
    Awesome that HH are coming to the party.
    But funny that you mention the rudder. I had a sticky rudder on mine. It would not return to centre & the servo would be noisy because it always had a load on it. It ended up being the control rod binding up on the rudder. A bit of light oil in the tube for the control rod & some rubber grease on the control rod & all is good. I will be keeping a close eye on it though. Must of been a Friday plane lol.
    Thanks, I would strongly suggest replacing that rudder servo if you had a hard landing. Another Cherokee pilot had a hard landing and it stripped the servo. He caught before the next flight and upgraded it with a metal one. I am using EMax ES08MA II servos in my replacement Cherokee. I am also going with a servo saver for the nose gear push rod. Operating off of grass that isn't perfectly smooth probably causes some torque loads going through the strut and being transmitted into the servo. The spring on the servo saver will take up some of that loading. I expect to lose some steering precision, but not worried about it since I don't taxi with the plane. I walk it out to the runway, aim it into the wind, and go from there. With take-off flaps, it doesn't have too much time on the ground where I need steering.
    Good tip on the control rods and something I will do while mine is all apart.
  • mrmat01
    Originally posted by BRGT350 View Post
    Thanks Loneflier, looks like I am getting a replacement Cherokee. Horizon completed the accident investigation and concluded the rudder servo stripped. They couldn't determine the cause of the stripped servo as it could have been the accident. Could have been me trying to get the servo the move when I had it on the bench. Either way, they are making it right. I am going to upgrade all the servos to metal gear Emax units and a servo-saver to the front landing gear push-rod. My theory is that shock loading from the front landing gear being inputted into a servo isn't good. I don't think this caused the servo failure as the plane had very few flights on it and the smoothest landings I have ever had. I almost never taxi the plane on the grass, I walk it out and back from the runway. I am positive the failure was a freak event with that servo. It is my first servo in 20 plus planes and 680 flights. Chances were good it would happen eventually. I will feel better with metal gear servos as an extra level of insurance. Will do the same to my Timber and B-17 rudder and elevators. I am so happy Horizon is taking care of me with this. I love the Cherokee!
  • mrmat01
    Originally posted by AZFlyer View Post
    Glad to hear it went well for you.
    How is the quality of the nose gear? My local hobby shop guy told me his nose gear broke on the first landing, and he's heard that complaint from a couple of other guys.
    Any issue there? Nice looking plane that I bet flies great.
    I think the nose gear is pretty tuff.
    On my second flight yesterday I misjudged the wind gust & stalled. It came in pretty hard on bitumen from about a meter+. It came in so hard it had a prop strike & popped the axel out of the wheel pants on the mains. It hit nose wheel first & it took it well no damage & 30 seconds with a screwdriver & I was back in the air. So as for the nose gear being fragile it’s not it exceeded my expectations.
    This plane is awesome & I would recommend it to anyone as s second plane.
  • BRGT350
    F22trainer, my Mustang would love Arizona! The car is setup to run open track and autocross events, but hasn't seen a track in years. For street use, the car runs way too cold and I have to block off most of the radiator in the summer. When temps get over 80'F, the car is happy. That means it doesn't get out very much in Michigan, except this summer when we had record temps and 20 days when it hit 90'. That is highly unusual. With all the insulation, sound deadening material, and HVAC removed, it gets a bit toasty in the cockpit on hot days. Flying season is about done for me and I am putting winter tires on my Fiesta tonight. It was 84'F last week and we had snow flakes falling this past Monday. Freezing temps and mixed precip forecasted after tomorrow. :(
  • F22trainer
    Thanks Alpha.
    I wrapped up putting my Mustang away for the year yesterday and moved the Cherokee into the basement to be completed. :( Always sad when fall arrives and the Mustang has to sit until spring before it comes back out. Depending on the weather, the Cherokee might not fly until next spring. I really dislike this time of the year.
    How do you feel about Arizona? Bring her on out when you finish, and you should be able to get it in the Mustang for a stroll down Route 66. While Corvettes are the sports car of choice, Mustangs still run in herds all across the Southwest.
    Our flying season is just getting started.
    Your Build is looking great and look forward to seeing it finished.
  • BRGT350
    Originally posted by Alpha.MotionRC View Post
    Nice Cherokee, and even nicer Mustang!
    I'm excited to see what your final Cherokee looks like with this new scheme. Callie is the best.
    Thanks Alpha.
  • BRGT350
    Slowly starting to come together
    E-Flite Cherokee repaint project by Bryan Redeker, on Flickr
    Callie is wrapping up the graphics and once those are done, the plane can start going back together. The aileron servos have been replaced and next up is the stabilator and rudder servos. Not sure how to extract the flap servos from the wings yet. Last step is the scale details like the exhaust tips, antennas, grab handle, foot step, and anti-slip walkway. Probably going to tackle the cockpit over the winter.
  • CaptAmerica
    Glad Horizon made it right.
