Quick Question - Admiral dsmp Stabilizer channel issue
This topic is closed.
  • Quick Question - Admiral dsmp Stabilizer channel issue
    Hi there,
    I know this probably a really basic question that I am just missing the solution but I needed some help. In the past I have only built and flow small electric RC planes with Spectrum receivers and controllers with pretty much no problems at all. Then I was given a larger, mostly built, gas engine aircraft just to complete building(essentially just finishing the electronics). This is where the issues start, multiple people had been messing with it so by the time I started working on it all the wires had been exchanged and moved around and the engine wouldn't start. luckily through a mixture of experience, YouTube and online manuals I was able to wire everything correctly and get the engine running. With one exception, for some reason on the receiver the elevator and ailerons give the same output signal(When I pitch up or down, the ailerons do full bank to either the left or right). I don't think this is the controller( A Spektrum DXe) because to my knowledge there is no way to combine channel outputs on it. Any help would be appreciated.
    Thank you.
    It’s not necessary to post up multiple threads on the same thing.
      Closing this thread because question has been asked and answered on the duplicate
