XK 1200 Cabling Issue
  • XK 1200 Cabling Issue
    Hello,
    I recently had a rough landing with my XK 1200 aircraft, and the inside cabling got disconnected. I do not have any pictures of how it is supposed to look, so I tried some combinations, and the elevators were vibrating while the plane beeped.
    I would like to know if anyone here could help me find the right combination of cablings inside, to make the plane fly again.
    Thank You
    Alvar
    This is from Page 7 in the manual if it helps...
      Thank you, but what would help is a picture of the correct cabling, as the cables that got disconnected are the blue, yellow, black and red ones.
        Sounds like the wires from your ESC are the ones you're referring to. If you are just getting beeping noises that is usually the ESC telling you there is a connection fault. Hopefully someone that has the XK A1200 will chime in but have you tried contacting Motion RC's technical support? They are usually very helpful.
          No, I have not tried contacting them, but I will now.
          Thank you for all your help!
