EFlite Conscendo Flaperons
  • EFlite Conscendo Flaperons
    I've done flaperons before on a spektrum receiver and my DX6 transmitter. I tried it on the Conscendo... flaperon in the airplane setup. One aileron to the aileron channel. The other to the flap channel, 6. AR637TA receiver that came with it.
    When I work they ailerons, they go up and down in tandem. Both up or both down. When I operate the flap switch, one goes up, one goes down.
    What the heck?
    Try swapping the ports. You also have to play with the reversing till it works right.
      Swap ports and or reverse servo channel u will find it
        The problem is the as3x gyro settings. The wingtype is programmed into the receiver.
        You may need to swap out receiver as not all 636s can be reprogrammed.
        Load the receiver into the as3x programming tool and see if you can make the necessary modifications.
        He very careful, because if you don't absolutely verify the gyro is moving the right surfaces, you will lose your plane. Test, test and test again before you fly
