SonicModell Talon GT Rebel 1000mm (39.37") - PNP from ZOHD - ZOH10045
The Talon GT “Rebel” is the continuation of ZOHD's new series called MKII, started with the highly acclaimed Dart XL “Extreme”. This series will feature an incredible set of high quality and ORIGINAL innovations, intended to give you the FPV aircraft for casual, mid and long range.
With MKII, without cutting any corners, they went straight ahead with 100% biodegradable and environmentally friendly materials, metal gear servos, high-quality power plants, protection for leading edges and skids, wing fences, vortex generators, dedicated bays for FPV gear, revolutionary multi-cam hard noses and much, much more.
Talon GT is one of the most capable FPV-ready planes regardless of wingspan and price. Can compete in range and speed with planes twice as big and twice the cost. Specifically designed to fly with modern flight controllers, high power video transmitters and long-range systems, Talon GT will give you the best FPV experience to date. Easy assembly, setup, and maintenance… A true king of the skies!
Easy Assembly and Transport The detachable wing and vertical fins makes the Talon GT Rebel easy to transport. |
Forward-Thinking BEPP Construction The Talon GT Rebel is molded using 100% biodegradable EPP (BEPP), built-in CF spar for enhancement, stable flying capability and impact resistance. |
Large Battery Bay The Talon GT Rebel incorporates a large battery bay for your chosen FPV equipment and electronics. |
Camera Compatibility The multi-camera nose is compatible with 99% of the FPV and HD cameras in the market: Runcam HD, 2, 3S, Swift, Split, GoPro H4-5-6-7, Session, and much more! |
- Thanks to its revolutionary design, the plane performs and looks like no other in the market
- Small size airframe optimized for long range and portability with cutting-edge production technologies
- Carefully chosen airfoil gives the aircraft an incredible lift power and excellent handling in any circumstances
- Detachable wing and tail make it portable for easy transport
- Familiar V tail layout, easy to set up
- ZOHD’s exclusive BEPP material isn’t only crash resistant, but 100% biodegradable
- Lightweight composite hard nose for better protection of your expensive camera gear
- Multi-camera nose: Compatible with 99% of the FPV and HD cameras in the market
- Reversed wingtips, provide more lift force and ensure an efficient wing surface
- Carefully engineered wing fences
- Reinforced pushrods for better overall performance and safety
- Load it as much as you want due to the large equipment bay
- Computer designed optimized air flow pod that maximizes cooling, reducing the risk of crashes for overheated electronics. No more DIY foam cutting!
- Impact resistant protective cover for main wings leading edge and belly will keep your plane away from wear and tear
- Built-in carbon fiber spar inside main wings for enhanced performance and rigidity
- Built-in carbon fiber square rod reinforcement all along the fuselage
- Exclusive VTX / RX bays with excellent airflow and away from interference
- U-stand for comfort and convenience while setting up the plane
- ZOHD SonicModell Talon GT Rebel 1000mm (39.37") - PNP
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 4 Cell 14.8V 2500 - 3300 mAh LiPo Battery - we recommend the Admiral 3000mAh 4S 14.8V 35C LiPo Battery with XT60 Connector
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 1 HOUR
Wingspan | 1000mm / 39.3in |
Length | 660mm / 25.9in |
Weight (w/o battery) | N/A |
CG (Center of Gravity) | Refer to manual |
Power System | 2216-1300kV Brushless Outrunner Motor |
Electronic Speed Control | 40A |
Propeller / EDF | 8x5 |
Servos | 9g metal gear |
Landing Gear | N/A |
Required Battery | 4 Cell 14.8V 3000-3300 mAh LiPo Battery (required) |
Required Radio | 4 Channel (required) |
Ailerons | Elevons |
Elevator | Elevons |
Rudder | Yes |
Flaps | No |
Lights | No |
Hinge Type | Foam |
Material | BEPP Foam |
Skill Level | Intermediate |
Build Time | 1 Hour |
Recommended Environment | Outdoor |
