Popwing Black 900mm (35.4") Wingspan - ARF BUNDLE from Skynetic - SKY1017-002
Click here for the official product page
The Skynetic Popwing EPP flying wing is constructed of durable EPP foam that is tailor-made for countless of hours of outdoor flying fun. Whether you fly the skies solo or engage in combat flying with friends, the Skynetic Popwing EPP is sure to please both intermediate and advanced pilots.
FEATURES:
- Small flying wing provides countless hours of flying fun
- Constructed from durable and light EPP foam
- Easy to build, fly and maintain
- Skynetic Popwing Black 900mm (35.4") Wingspan - ARF BUNDLE
- AS2208 KV1260 Brushless motor
- 20 amp brushless ESC with XT60 connector
- 2x 8g micro servos
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 3 Cell 11.1V 800 -1000mAh Li-Po battery with XT60 connector - we recommend the Admiral 1000mAh 3S 11.1V 30C LiPo Battery with XT60 Connector
- 3 Cell compatible battery charger - select a minimum 3 cell (3S) charger from our Charger Collection
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 4 HOURS
Wingspan | 35.4in / 900mm |
Length | 22.6in / 575mm |
Flying Weight | 300 - 350g |
CG (Center of Gravity) | 200 - 212mm from the leading edge of the nose |
Power System | Powerful AS2208 KV1260 Brushless motor (installed) |
Electronic Speed Control | 20 amp brushless ESC with XT60 connector (installed) |
Propeller / EDF | 7 x 5 Electric propeller |
Servos | 2x 8g micro servos |
Landing Gear | None |
Required Battery | 3 Cell 11.1V 800 -1000mAh Li-Po battery with XT60 connector (required) |
Required Radio | 4+ channel radio system (required) |
Ailerons | Yes (elevons) |
Elevator | Yes (elevons) |
Rudder | No |
Flaps | No |
Lights | No |
Hinge Type | Foam |
Material | EPP Foam |
Skill Level | Intermediate |
Build Time | 4 Hours |
Recommended Environment | Outdoor |
