Can anyone tell is there need of thrust angle in delta wing of single motor...and also in rectangle board wing..and if yes then angle measure???
Thrust angle for flying wing
If it's a "tractor" type (as opposed to a "pusher" type), a rule of thumb is about 3 degrees down angle on the motor and 3 degrees to the right (if you are using a standard rotation prop). You can still make it without any deviation from straight thrust line but then you simply have to use trim to make it fly straight.
