Official ZOHD MKIII Alpha Strike 900G 620mm Thread
  • Official ZOHD MKIII Alpha Strike 900G 620mm Thread
    MKIII Alpha Strike 900G 620mm (24.4") - PNP from ZOHD - ZOH10069
    The MKIII Alpha Strike has a wing body design with an airframe that is molded from EPP and enhanced with carbon fiber, which also features Sharp Airfoil Design. This new MKIII phase of products includes a commitment to higher-end design, putting emphasis on enhanced aerodynamics. Take this FPV-capable craft to new heights and explore the wide flight envelope while enjoying the first class customer support you have come to expect from Motion RC.
    Sleek and Aerodynamic Stylings
    The MKIII Alpha Strike is a clear and concise departure from the older, less aerodynamic profiles expanding the pilot's flight envelope to include aerobatics with ease.
    Detachable Wings
    Although already a sleek, smaller scale profile, the MKIII Alpha Strike has detachable wings and tail fins for added convenience for transport and storage.
    Molded Hand Launch Grip
    The MKIII Alpha Strike takes the stress out of hand launches by offering pre-molded hand launch grip points to make your hand tosses comfortable and easy each and every time you fly.
    Generous Space for Battery and FPV Gear
    The battery bay of the MKIII Alpha Strike is plenty spacious affording ample room for your chosen 4S LiPo battery and any FPV gear you require (not included).
    • A specially-designed servo arm “bunker” structure protects your servo arm from impacts and minimizes drag
    • Compatible with most racing quad drones and FPV gear
    • EPP molded airframe and built-in carbon fiber spar for enhancement
    • Innovative Sharp Airfoil design and aerodynamic airframe
    • Detachable wing and tail fins, portable and easy to pack
    • Innovative Twin Bay Design: Limitless options for setup
    • Teflon skin protection to avoid scratches when landing
    • Molded hand grip slots for a worry-free hand launch
    • Improved air rolling design to protect your gear
    • ZOHD MKIII blended wing body configuration
    • Molded marks for “CG” under the wing
    • Super stable flying performance
    • ZOHD Alpha MKIII Strike 900G 620mm (24.4") - PNP
    • 2216-2200Kv brushless motor
    • 40A ESC with 5V/3A BEC
    • 6x4.5 propeller
    • 2x 4.3g servos
    • Owner's manual
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :1 hour
    Model Scale N/A
    Wingspan 620mm / 24.4in
    Length 650mm / 25.5in
    Weight 900g / 31.7oz
    CG (Center of Gravity) Refer to owner's manual
    Power System 2216-2200Kv brushless inrunner motor
    Electronic Speed Control 40A with 5V/3A BEC
    Propeller / EDF 6x4.5 2-blade
    Servos 2x 4.3g servos
    Landing Gear N/A
    Required Battery 4 Cell 14.8V 2200 - 3200mAh LiPo battery with XT60 Connector (required)
    Required Radio 4+ Channel (required)
    Ailerons Elevons
    Elevator Elevons
    Rudder No
    Flaps No
    Lights No
    Hinge Type Nylon
    Material EPP
    Skill Level Intermediate
    Build Time 1 Hour
    Aros, is this an entry-level FPV aircraft? I ask only b/c I've been thinking about FPV as the new frontier and a cool trick for a very old dog. Best, LB
    Captain: Got any ideas?
    F/O: Actually not.
      My friend I believe this would qualify although I am by no means an expert on ZOHD models. If you get one and you find it's a bucking bronco in the air I am going to blame Hugh.
        One of my next planes but the big question- what about spare wings?
        Just let me fly so I may be free
