MKIII Delta Strike 750G 600mm (23.6") - PNP from ZOHD - ZOH100-71
Proudly introducing the new ZOHD MKIII Delta Strike - the first FPV 50mm EDF jet, with a built-in 180° pan servo! ZOHD has touched upon every sector when it comes to fixed-wing FPV platforms: Long-range, speed, sub 250 grams, and everything in between. Now is the time to explore a whole new bold and exciting FPV experience. Take your FPV skills to a new level with this EDF-powered platform. The EDF propulsion system also adds a safety feature, illuminating the risk of getting your fingers hurt from a faulty hand launch.
All of that, combined with the amazing sound and the immersive experience of the 180° pan to look over your wings in the turns, will give you an improved and amazing FPV experience. Take this FPV-capable EDF craft to new heights and explore the wide flight envelope while enjoying the first class customer support you have come to expect from Motion RC.
Sleek and Aerodynamic Stylings The MKIII Delta Strike is a clear and concise departure from the older, less aerodynamic profiles expanding the pilot's flight envelope to include aerobatics with ease. |
Detachable Wings Although already a sleek, smaller scale profile, the MKIII Delta Strike has detachable wings, nose and tail fins for added convenience for transport and storage. |
Molded Hand Launch Grip The MKIII Delta Strike takes the stress out of hand launches by offering pre-molded hand launch grip points to make your hand tosses comfortable and easy each and every time you fly. |
180° Pan View A custom-designed servo bay on top of the fuselage allows the pilot a 180° pan view with their chosen FPV gear (not included). |
- A specially-designed servo arm 'bunker' structure will protect your servo arm from impacts and minimize drag
- Custom-designed servo bay on top of the fuselage for a 180° pan view
- Ball head buckle linkage for ailerons, high efficiency and more accurate
- EPP molded airframe and built-in carbon fiber spar for added strength
- Detachable wings, tail fin, and nose - portable and easy to pack
- Spacious room inside the fuselage for batteries and FPV gear (not included)
- Innovative designed airfoil and aerodynamic airframe for increased performance
- Molded hand grip slots for a worry-free hand launch
- Clever air cooling design to protect your FPV gear (not included)
- ZOHD MKIII blended wing body configuration
- 'Inside-The-Cockpit'' Immersive experience
- Molded marks for “CG” under the wing
- ZOHD MKIII Delta Strike 750G 600mm (23.6") - PNP
- 50mm EDF with 2611-4000Kv brushless motor
- 40A ESC with 5V/3A BEC
- 3x 9g servos
- Owner's manual
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 4 Cell 14.8V 1800 - 2200 mAh LiPo Battery - we recommend the Admiral Pro 2200mAh 4S 14.8V 45C LiPo Battery with XT60 Connector
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
AGE LEVEL :14 and up
SKILL LEVEL :intermediate
BUILD TIME :1 hour
Model Scale | N/A |
Wingspan | 600mm / 23.6in |
Length | 610mm / 24.0in |
Weight | 750g / 26.4oz |
CG (Center of Gravity) | Refer to owner's manual |
Power System | 2611-4000Kv brushless motor |
Electronic Speed Control | 40A with 5V/3A BEC |
Propeller / EDF | 50mm EDF |
Servos | 3x 9g servos |
Landing Gear | N/A |
Required Battery | 4 Cell 14.8V 1800 - 2200mAh LiPo battery with XT60 Connector (required) |
Required Radio | 4+ Channel (required) |
Ailerons | Elevons |
Elevator | Elevons |
Rudder | No |
Flaps | No |
Lights | No |
Hinge Type | Nylon |
Material | EPP |
Skill Level | Intermediate |
Build Time | 1 Hour |
Recommended Environment | Outdoors |
