Edf esc fast pace beeping
Hi all so I have finally found the final hurdle. The local club member had another look at my plane after getting further advice and found it was between my receiver and transmitter. The reason for this is futaba have been known to send receivers that need resetting as they have been set up for 16 channels where two 8 channels receivers buddy up to make 16 channels. My receiver was set to above 8 which is why my 8 channel transmitter couldn’t calibrate my esc. After resetting my receiver and changing it to channels 1 to 8 my transmitter calibrated and armed the esc correctly. :)
Hi all
For those that were wondering what the fault was well...
I took my plane to my local club and I had two seniors who have had 30+ years in this hobby and they diagnosed the fault which was the planes freewing blue control box which was preventing the signals to the single wires to the receiver. So they bypassed this control box with y plugs straight to the receiver and the plane works fine. However this was with their receiver and controller my controller and receiver still makes multiple bleeps due to futaba set up the seniors did not know how to set up the esc with futaba. However there is a younger club member who is coming round today who will be able to calibrate my futaba set up as he is the only one that uses futaba.
Originally posted by kallend View PostSo we can not really draw any conclusions from the presence of audible beeping.
If I were a betting man, I'd put my money on the throttle channel not being properly set up to initialize the ESC.
I think this YouTube video at time 09:10 https://youtu.be/U6djMJYYaiA
is what’s happening with my esc I inspected the wires last night and they seem well connected I have a voltage meter I found secure connections. I have found a club 30 mins drive from me to take it too. Might subscribe to fly there also I already have my CAA license for (Uk)
Originally posted by xviper View PostHere it is. With all wires connected and then one wire disconnected. Different ESCs and different motors will make different tones and at different volumes.
(This is the last time I'm going to "prove" myself to someone on the internet. If you don't believe me, so be it. If your "facts" don't coincide with my "facts", so be it. If you are happy with what you believe, great. Fill your boots.)
I never asked you to prove it to me, I did my own test and got some same and other result than you.
Kind regards Hans
I just tried to video this phenomenon but I can't get it off my Iphone so I can post it on YouTube and embed it here. I'll try it again later with a different video camera.
In any case, I knew I was NOT dreaming this up. If a certain wire on the motor to ESC is disconnected and I attach the battery, it gives a rapid beeping (cell count) on an outrunner EDF, it is just as loud as if all three wires are connected. However, this ONLY happens if a particular wire is pulled. If either of the other two are pulled, there is no beeping. Nothing happens.
In the case of the OP, this "could" be what's happening.
Unbiased arbiter here.
FW 70mm 12B inrunner with Avian 80A ESC.
3 leads attached - loud beeping.
2 leads attached - very faint beeping (had to put my ear really close to hear it).
The beeps come from the motor windings being energized at audio frequency by the ESC, The ESC itself doesn't make a noise.
I'll have to give it a try with both outrunner and inrunner EDFs. It could be I was hallucinating.
Originally posted by xviper View PostIf only 2 of the 3 wires are hooked up, it will still beep and cause the motor to pulse with with each beep. I may be dreaming but next time you are messing with the motor and esc, try it and that will confirm or reject what I just said.
Don't know what triggered you regarding you're answer.
But I just checked it with 2 different ESC'n, using a brushless outrunner and with 3 cables connected I got beeps and with 2 nothing😉
Maybe with a EDF unit and inrunner it is as you say but I have to test that next time when I have my EDF on the table😏
Regards Hans from The Netherlands
Originally posted by timmybeetle View Postps2 if the motor beeps than normally the wires are connected as they should otherwise you did not get the beeps.😉
Thank you all for your advice I have no experience only with small planes and virtual simulators. I have much to learn. I will look into the throttle curve I read the manual again last night and seen that part. I think for myself I should go to a local hobby club or shop if this doesn’t work as I appreciate it’s difficult to translate over text. I will keep you updated in case it’s something more than it is.
Originally posted by lew View PostHi there
thank you for getting back to me. I am still new to this hobby and not really sure what the process is. Please can you provide a step by step process for a dummy?
For us to help true the internet is a hard way to do and nearly impossible to a person who is new to this hobby an has totally no experience what so ever.
The only advice we give is go to a local club and let you help there, that's the only way to be save.
What is yours building experience, technical back ground?
what are you're flying skills?
what did you fly before!
etc etc...
Regards Hans
ps before you can arm a ESC you have too make sure that the Throttle curve is programmed into the ESC.
Its explained in the manual of ESC
I own a futaba myself and you have to reverse throttle channel in order to do this.
Your questions suggest you need in-person help. Would you expect to fly a full-size plane with just instructions from the internet?
A loose wire is not really a "faulty" product. I've seen those wires come loose during transport on a few planes because they weren't pushed on firmly at the factory. Being new to the hobby, you likely just don't realize that these sorts of things are natural occurrences and is part of the inspection and set up process with any RC model.
Originally posted by lew View PostThey look like they are but my edf is difficult to get to the motor as it’s inside the model
