Originally posted by Apache Jets
View Post
Freewing 80mm F-5E Tiger II
Thought I'd throw this on here for those who would like to increase the flight time on the 80mm F-5E. Hobbystar 4200mah 6s 40c's are incredibly light and with 8400mah's on board 6 minute flight times are the norm. Landing with 3.8volts per cell. If you prefer to fly her with the 4000mah 6s batteries, then maybe this isn't for you, but I can't tell the difference between a 5000mah 6s, and a pair of 4200mah's in the air.
Originally posted by Phantom View PostThought I'd throw this on here for those who would like to increase the flight time on the 80mm F-5E. Hobbystar 4200mah 6s 40c's are incredibly light and with 8400mah's on board 6 minute flight times are the norm. Landing with 3.8volts per cell. If you prefer to fly her with the 4000mah 6s batteries, then maybe this isn't for you, but I can't tell the difference between a 5000mah 6s, and a pair of 4200mah's in the air.Check me out on youtube at https://www.youtube.com/user/gooniac33
Originally posted by gooniac33 View Post
WOW never seen that much in there before. I am flying with the fms fan and using a 6s 30c 5000mah pack now. Have been getting 3-5 min flight times depending on how I am using the throttle. I am sure your plane likes the extra discharge rate as well!! Should be really good!
it has a small wing so landings are reasonably fast. When mine had the stock fan landings were for sure hot. But once I changed to the FMS unit the landings were much better. Still faster than most but for sure slower than in stock format.
I Need your help! I am flying the F5 with the 1680 FW inrunner and I am completely happy with Sound and performance from it (40C 6s battery pack, 648grams). My Problem is the Approach and landing in a very confined area with a 200 feet groomed grass Strip. I handle the Mirage 2000 just fine and cannot belief that there a pilots out there trying to tell you that the F5 was a ***** cat compared to the Mirage. The F5 Comes in hot most of the time as I try to avoid overbanking which, by the way, it sure doesn't like it. There seems to be a mystery surrounding the correct cg for the Swiss version (what is it in mm from the nozzles)? I am employing full flaps late crosswind (about 60mm) and still come in hot. I know, if I had a long enough final and a long runway, I would bring in this sucker home safely most of times, but not in a confined area such as ours. How can I improve on this Problem?
Thanks Gooniac for your feedback!
Originally posted by Walo View Post
Hi Gooniac
Thanks Gooniac for your feedback!Check me out on youtube at https://www.youtube.com/user/gooniac33
Hi Gooniac
Don't know if this will help, but I assume from your reference about the Mirage that you are landing the F-5 in a high alpha attitude. I use 80 degrees of flap, it looks almost 90 degrees straight down from the wings. My approach to final is pretty steep, about 25 degrees nose down, and I'm still dragging it in with a little power. It takes a little practice to get your sight picture down for a greaser everytime, but the transition is from 25 degrees pitch down to about 20 degrees pitch up with just the slightest reduction in throttle and you touch down at a nice controllable ground speed. I land on pavement and am able to turn without wingtip scrap with about a 100 ft of roll out. Grass should be even easier to show down. I fly it completely stock and with two Hobbystar 6s 4200 packs on board for a grand total of 8400mah in the gas tank, if you are comfortable with your rotation skills try to drag her in with FULL flaps, see how you like her, she's my 3rd favorite for landing, after the F-86, and the Venom, and I own almost all of FW's 80mm and 90mm EDF's, I find her to be easy to land.Check me out on youtube at https://www.youtube.com/user/gooniac33
If you can land the mirage easily then this one should be simpler. The problem with that set up is that it is heavy... When the plane is heavy its not all that easy... you just need to shoot some touch n goes to get used to it. The main problem is that when the plane gets slow the power plant can't react fast enough to get it out of trouble. the inrunner willbe an improvement over stock for sure... but the FMS is totally worth the effort and the weight savings make it much easier to handle...
I will Keep trying until I get it right (providing the plane survives)! I may try a lighter battery pack for starters and see how it goes.
I learned the hard way that the F5 doesn't like high alpha as much as the Mirage does. The Problem is the final turn which must be in a slightly nose down attitude and with Little bank. At some point I have to raise the nose in order to slow the plane down and then stay in the power. With the flap setting you are suggesting, what will be the down Elevator mixing rate in % or mm?
That is definitely a steep and advanced approach. Yes it can be done but I never recommend using that much flaps with this plane because it requires such a high throttle setting to keep in the air. The nose needs to be pointing at the ground or it will stall on you! Also with your higher than normal wing loading the flaps may not affect the plane quite as much as a lighter one will.
I have zero mix between the elevator and full 80 degrees of flap. I've slowed the transition time to a full 3 seconds but after keeping some forward pressure on the pitch stick to prevent ballooning during the flap movement, I can relax in the stick and she's perfectly balanced again. I hold forward pressure to keep her nose down during my base and final turns, but when I'm ready for touchdown all I do is slowly relax the stick to the sprung center position and the when I get my final descent started in ground effect I pull the nose gently up. If the majority of folks are flying her in high alpha attitudes for landing, then my 2 cents is, they're working too hard. The F-5 may have small wings, but it's a beautifully balanced design. Ole Chuck Yeager used to say aside from the F-15, the F-5 was his favorite, because it was such a great flyer, a really great designed airplane. With the liberties that freewing took with this model's airfoil to increase lift, she really is a sweetheart in my book.
tried out some new batteries on my FMS equipped F-5... 6s 40c 5000mah China Hobby Line Black series packs... WOW!! What a great match!!! The plane is even better than expected!Check me out on youtube at https://www.youtube.com/user/gooniac33
Originally posted by gooniac33 View Posttried out some new batteries on my FMS equipped F-5... 6s 40c 5000mah China Hobby Line Black series packs... WOW!! What a great match!!! The plane is even better than expected!
I got that email when they first came out and bought a couple but haven't flown them yet, great to hear they impress!
Here are the videos with the new ones...
Originally posted by Phantom View PostKorean version of the F-5. They are still on active duty. Never realized how far forward on the fuselage the center tank sits!Check me out on youtube at https://www.youtube.com/user/gooniac33
Looks like the next plane to get a high performance version is the F5!
F-5 Tiger II Camo High Performance 80mm EDF Jet from Freewing - PNP - FJ20815P Version Info: This is the High Performance version of the Freewing F-5 Tiger II. As of 6/22/2023 this model now comes with the upgraded 3658-2150Kv inrunner brushless motor, a newly designed 12-Blade EDF, 100A ESC and hybrid metal gear servo
