https://www.youtube.com/watch?v=PU8328tWOK8....mix shown at end of video. (12:23 Mark)
Originally posted by Rudderman98 View PostHey fellas.
Anyone have the elevator to flap settings for the L-39? I've been having some issues getting the right settings. I have the DX-18 Tx.
this is what I have on my FW A4 as another example
Rich
Originally posted by xviper View PostIf you take a look at Rich's settings, you can see that the numbers are different from one plane to another and even with mulitples of the same plane. What your settings will end up being is dependent on where in the flap servo arm you began to size up and attach the rod and also on whether or not you are using any flap servo sub-trim to begin with to get the flap servo closer to the beginning (zero flap) of its travel. So seeing someone else's flap settings may not necessarily be what you will use for yours. If I put up my L-39 settings, they will look different from Rich's.
Rich
Originally posted by John Bergsmith View PostPut the first two flights on the L-39 today. What a nice flying airplane. Installed a AR636 receiver so I’ll continue to adjust the gyro gains. Plane is smooth and precise. The Russian scheme show up great in the air.
Tom
BTW: first two flights were clean, second two with all the goodies on it and didn't see any significant change in it's performance.
I fly from a textile runway at my club field. Over the Labor day weekend I flew at an Airport. I went off the runway, which put my gear to the test. When I retracted the gear the left side wouldn't fold into the well. Here the pivot point was very tight and wouldn't allow the wheel to go back to it's normal position. It was binding at the knuckle. Tonight I sprayed the pin at the knuckle with penetrating oil and it now pivots freely. Just something to look for.
Tom
- Likes 2
Just wondering if anyone else has had trouble fitting the gun pod on their L39? Mine slides on initially and then jams up about 3/8 of an inch from where I assume it is supposed to be. ( Where the red trim lines would meet) I opened up the gap in the pod where the lugs on the plane should slide and even added a little silicon grease to help out but with no luck.
Any suggestions? Thanks flyers!
