Originally posted by Scale Master View Post
They were 3d printed then wired up the LED's in them. There is some videos on YouTube showing how to do it.
If you want to purchase this kit send me an Email toSolt4923crew@hotmail.com
- Likes 2
Originally posted by Jonybonbon View PostI got his light set for F22 & A10, it is way cool and pretty easy to install actually.]I solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
I fly mine on 12S, and I modified the battery area by running the wires to the sides of the battery tray. Then I put one 6S shoved all the way back as far as it will go, and the other in front of it, and it comes within 1" of the junction box. All wiring, including the RX, is stuffed under the battery tray. Using 2 6S 4500 70C packs, it balances just fine. You could do the same with the pair of 6S in parallel if necessary.Pat
He's talking of putting a pair of 6S 4000's in parallel on a 6S setup...
Originally posted by crxmanpat View PostI fly mine on 12S, and I modified the battery area by running the wires to the sides of the battery tray. Then I put one 6S shoved all the way back as far as it will go, and the other in front of it, and it comes within 1" of the junction box. All wiring, including the RX, is stuffed under the battery tray. Using 2 6S 4500 70C packs, it balances just fine. You could do the same with the pair of 4S if necessary.
Originally posted by Evan D View PostHe's talking of putting a pair of 6S 4000's in parallel on a 6S setup...
EDIT - I think I see now. I said a pair of 4S in my original post, but I meant 6S. I fixed the original post.Pat
Hello everyone - just got my Freewing 90mm 8S F-22! Wondering if there is any sort of comprehensive list of recommended mods for this kit? I'm reading all kinds of posts regarding:
Bypassing the blue box
Different bec than the one included
Running separate receiver battery instead of bec
Problematic stock servos
Use Spekrum receiver / Don't use spektrum receiver
etc etc
It's enough to make my head spin... I really don't want to crash this jet due to faulty (insert favorite hated part here). Maybe I'm worrying too much?
