Luckily the 90mm F-22 has a huge presence in the sky
Originally posted by Av8er278 View Post
Nice to hear that. My 4s funjet does about 110-120 mph the 6s funjet does about 200-215 mph. I’m use to the fast flights but seeing them sometimes is the challenge.
It seems huge and on 6S visually slow when you first fly it. My first thoughts when I first got mine was "this thing is huge" (it was my first 90mm) and "why is it going so slow". It's deceptive.
Depends on too many variables. What 8S set up, your style of flying and throttle usage are the main ones but altitude, wind and other things can effect it too. I have a JF/ HET 8s and run 5200's for 4:30.
That it's 4+4 doesn't matter.
There was a question on brakes. This plane can land very slow and I don't have brakes on mine but many have put them on theirs. Maybe ask on RCG too?
Originally posted by gooniac33 View PostThe way that this balance adapter is wired will pull 2s voltage from your 6s pack. Connect this to your balance lead on your battery and it will give your Centerburner the power it need to operate. No need to connect to anything else. Just the balance lead on your battery. My LED Afterburner set up works the same way by getting voltage through the adapter but it operates off of 3s voltage. Its really simple and easy.
Originally posted by Evan D View PostDepends on too many variables. What 8S set up, your style of flying and throttle usage are the main ones but altitude, wind and other things can effect it too. I have a JF/ HET 8s and run 5200's for 4:30.
