2000mm Giant Scale B-24 - Silver
    Not really sure, sorry.
    looking at the old thread on the other site I said a couple years ago 150mm but I may have changed from then.
    Hi,
    What would it take to persuade you to measure it for me? ;)
    • Hi, the CG for my red raptor is 150mm. A correction for inverted level flight is not necessary with my plane.
      • I’ll try to do it soon.
        check and verified, 150mm.
          Hmph.
          I guess I'm very nose-heavy, then. :(
          Thanks!
          • Can some confirm if this lipo fits one an 8s setup?
            4s 5200 90c - size: 35X46.8X160mm x 2
            from the book is in the limit H=70.
            I have a chance to buy with 60% discount lipos for a 8s setup
            Tks
            • So two would be 70mm wide, 47 tall and 160 long, no problem. The F-22 has a very large battery area.
                Yes, but 70 is on the limit, if some reason have 36 dont fit.
                if some one measure i will appreciate
                • But 70mm is the width not the height. Mine are 75x 45x145 and there is a ton of extra room every dimension.
                  • Originally posted by electric jet View Post
                    Hello all, I finally found time to unbox and assemble my 90mm F22 and I have some questions. first off, with a admiral 5000 bat. I have to push the bat. back half way off the battery tray to even get close to neutral CG. with the gear up and the canopy cover installed it is still slightly nose heavy??...I see videos of guys pushing the bat. closer to the blue box and flying that way. I have checked my measurement (150mm from wing/fuse crotch) and accurately marked it. Do you all just fly nose heavy?Or is the plane not that sensitive? What am I missing.
                    Also, how much if any expo you guys using with this aircraft. I'm new to EDF, any advise would be appreciated. won't be flying till spring anyway. Thanks
                    Hi, I have the same issue or not, I have the battery back to get 150mm.
                    do you fly like this?
                    • Question does everyone check cg with gear down and plane in flying position not inverted ??
                      • Originally posted by Av8er278 View Post
                        Is there other possibility that that?
                        Badan Kit - Yak55M 2.8m; EF - Extra 300 2.3m; Multiplex - Funcub;Funjet Ultra2;FW - F22 90mm EDF;ROBBE MISTRAL 2.0
                        • Yes, gear down and upright.
                          • Thanks Evan
                            • Anyone's have cheating holes in this model?
                              • Anyone change the esc to have reverse thrust? If so what esc do you have?
                                • Originally posted by mribeiro View Post
                                  I believe that either the Spectrum Avian or Castle Escs support reversing
                                  • Am joining the show!
                                    • +1
                                      Very nice flying! Love the flat spins and those flip-floppy maneuvers near zero airspeed.
                                      • Thanks!
                                        • Flights 6 to 9! :)
