I would add that you should skip checking out the elevator servos and just replace with the F-22. And be sure to test ALL servos before assembly to ensure they all work as it seems there may have been a bad run of the hybrids (lots of reports of dead servos, or dying quickly).
Freewing is going to be putting all metal servos in the elevators moving forward, from what motion told me. Sooo there is something to be said there.Planes
- Likes 2
Originally posted by Carlbrainiac View PostThat's a lot of money to spend on an eflite model. Plus give it a year and they'll discontinue it and you won't be able to get spares.
Originally posted by DCORSAIR View Post
To funny right there , I didn't know that about Eflite, never owned any, if that's the case then I will pass for sure, do love the gear though.
Rich
Take the slop out of the pivoting rod for the full flying stab by undoing the 4 retaining screws and lay in a strip of paper in the bearing retainer top and bottom.
Take care when you position the wires for the rudder servos when you bolt on the vertical stabilizers.
Test your elevator servos. If they are juddery through their motion or even just towards the end of their motion. Bin them. The hybrid metal gear servos are not up to the job of that full flying stab in my opinion. Get the full metal gear versions as used in the 90mm F22 on it's full flying stab.
Check the security of your canopy. I lost mine on maiden. Piece of ply on the back of the canopy does not have a pre drilled hole for the pin and in fact doesnt line up with the pin. And the pin of the latch itself is also rather short. I added magnets either side of the latch and on the canopy itself.
Ignore manuals c of g recommendation of 88mm. Instead go to 90mm. This is easy done. Fingers on the back corners of the plastic forward wing mounting plate.
Add an additional and longer velcro strap for the battery. Also do away with the rubber battery gripped in favour of velcro on the tray and the battery. These are big heavy batteries and you never want them shifting position in any model. But especially not in a jet.
Think that's everything..
Originally posted by rcSpanky View Post
Awesome!, Thanks! I have seen that some people dont connect everything to the blue box, should I avoid that? Is there easier access to that device? It seems like an impossible effort to work inside there.
Originally posted by fredmdbud View Post
Also I got my Blue Angel in the air yesterday! got 4 awesome flights with my older F-15 Hopped up Set up. Hard to believe that I got this thing going back in 2016!! Leopard 4082 1600kv inrunner with the older Freewing 12 blade rotor and Gooniac Balanced of course! It did amazing in this plane and I am super happy with it! All of the hard work paid off and I am glad that I went through all of the issues that were being had with the bird! Will share video later...Check me out on youtube at https://www.youtube.com/user/gooniac33
Originally posted by thisguy65 View PostFreewing is going to be putting all metal servos in the elevators moving forward, from what motion told me. Sooo there is something to be said there.Check me out on youtube at https://www.youtube.com/user/gooniac33
I got 4 flights in crazy windy conditions. My field is 44 miles away so if its windy when I get there I am not gonna turn around and go home.... gotta fly!! Glad I did too because it went wonderful! Aside from trim not working on my left aileron for the maiden (I did get it fixed and working later) the plane flew great! Ailerons are super touchy!! I cut my throw down to 45% but I am also using towerpro MG90S servos which may have more travel than stock. I really cut down the elevator throw as well since I have different 17.5g JX servos there. I ripped off the elevator mounting plates and then put super thick CA there and they are not moving at all... Very happy with how it flew and by the 4th flight the wind had calmed and I was able to fly a little more aggressively. I am using a 3 year old set up that was in my F-15 back in the days but it moves this thing around really nicely! I am working on another MONSTER 6s set up that should be done by this week once all of the parts show. This set up should be capable of 4-8 min flying times depending on how you use the throttle.... more of that later when it shows... here are my flights and if you don't like hat cams just don't watch ok? thanks...
Also if you want to know how I set it up here are the specs...
Freewing 90mm inrunner housing
Freewing 90mm 12 blade rotor (older individual blade style)
Gooniac Balanced to perfection
Red Brick 200amp ESC
ZTW 10amp UBEC
LemonRX 7ch receiver
Towerpro MG90S Metal Gear Digital Servos (Flaps/Ailerons)
JX 17.5g Servos for Elevators
Gooniac's RC EDF Creations LED AfterburnerCheck me out on youtube at https://www.youtube.com/user/gooniac33
- Likes 2
Does anyone have pictures of their Admiral 5000 battery location? My first one went in due to elevator but with people mentioning they had their Admiral battery 3/4 of a inch from the front bulkhead has got me, well concern.
Planes
Originally posted by thisguy65 View PostDoes anyone have pictures of their Admiral 5000 battery location? My first one went in due to elevator but with people mentioning they had their Admiral battery 3/4 of a inch from the front bulkhead has got me, well concern.
My Admiral 6000 pack I run with it pushed up and almost touching the blue box
Planes
