  • Yeah i tried the same thing with the same result
    • Originally posted by andrew_flyguy View Post
      A good friend brought his over today so I could help him with some small maintenance items. While we were doing the surgery, we were going to have the landing gear bypass the board as to eliminate the delay, but found that the landing gear light WILL NOT operate if there are no servos plugged into the Landing Gear input slots on the MFCB... very odd, and a little unfortunate. Has anyone else noticed this?
      Yes - that keeps the LED unlit when the gear is up, saving battery and LED life. Use a Y cable to connect the landing gear channel to the blue box. Or if you have an available channel, mix the gear to that and connect to the blue box.
      • Originally posted by fredmdbud View Post
        We might give that a go. I misspoke. The Landing Gear light won't work unless there are landing gear servos plugged into the MFCB Gear OUTPUT slots.
        • Hey Y'all, For those of you who are not yet bored to tears with my Cockpit Build, here is the finished 'glued, screwed, and tattooed' product. I thank you for your patience. Best, LB
          • Just brilliant my friend.
            • Elbee.... :o
              • Zuper Zexy
                • Steve, absolutely outstanding, everything including the pilot, especially with the CAG on the helmet! Now that you're done, I'll send you mine and you can reproduce it.
                  • Hugh, You are soooooooo funny. Hah...Hah. Our deal still stands. Good Luck as there are no instructions, not even pictures with captions in Chinese. Best, Steve
                    • Awesome stuff Bro
                        Elbee, is that an issued "Pine Tree" air freshener? Is it really "Pine" scented or is it "New Plane Smell"? What is the Cage number so I can get one?
                          Click image for larger version  Name:	image_49242[1].jpg Views:	40 Size:	153.9 KB ID:	227047
                          Hardway, !! How very observant of you, Sir. It's part of the the Navy's new Hygiene Initiative Package (HIP) where Little Trees 'Pine' is SOP and includes Face, Pits, Parts Soap (FPPS) for longer lasting Odor Suppression in close quarters. Also, works well to minimize those pesky fluctuations during High-G events. Best, LB
                          • That G suit should keep the bottom squeezed...
                            • I'd say that's the 'bottom' line, wouldn't you?
                              • Dialed in and flying really well. Took some work, but worth it for the low passes.
                                • Originally posted by Jackcannon View Post
                                  JC, Bravo Zulu, Sir. Really great work, she's a 'beaut'! Best, LB
                                  • Thanks LB. I’ve got some work to do after seeing your cockpit mods. Really incredible work!
                                      Thanks Jack. I posted the F-18C Cockpit STL Files over on the Hobby Squawk 3D Printing forum if you have access to a printer. If or when that is the case, let me know if you're going to print anything as I have updated some of the parts. Understand that my prints are simply my interpretation for the Freewing model and are not nearly scale to actual, but those parts look pretty good once painted up and installed. Best, Steve
                                      • Posted this question on the T-33 log. I have just bind the plane to my AR636A and armed the esc. The only channel that works is the flap servo and throttle. All are going through the Blue Box. What am I doing wrong?
                                        • Originally posted by bmccool View Post
                                          I would say check the polarity of the male/male leads from the rx to the blue box.
