Can anyone tell me which Hitec servos fit the Freewing 9g servo pockets ? Hopefully with little, or no modification...... If such a servo exists. With metal gears ?
Originally posted by EDF_Lover View PostWow. I never thought a turbine mod. Have you flown the airframe with the electric fan? If I had to guess, you are going to get about 200 kph with that thrust. And, the ailerons are so large and effective, roll rates are going to be crazy high. So my advice, not that you are asking, would be to have high elevator rates for takeoff (80%?) but keep the aileron rates in the 40% range. Be prepared for a decent roll, but extreme nose high climb the second it lifts off.
I also learned a lot about its high alpha characteristics by spending by spending time at about 25 meters of altitude trying to simply fly as slow as I could. That’s very important for landing. It rolls more than it stalls, of course until it stalls! Ie it remains controllable longer than you think it will, but when it does break, it’s heavy and takes a lot of altitude to recover.
Originally posted by scootergenie View PostCan anyone tell me which Hitec servos fit the Freewing 9g servo pockets ? Hopefully with little, or no modification...... If such a servo exists. With metal gears ?
Size Category: Minis and Micros Type: Digital Application: 15-25 size aircraft Torque: 35 oz-in (2.5kg-cm) @ 4.8V; 42 oz-in (3.0kg-cm) @ 6.0V Speed: 0.14 sec/60° @ 4.8V; 0.11 sec/60° @ 6.0V Length: 1.1 in (28.0mm) Width: 0.5 in (12.7mm) Height: 1.07 in (27.4mm) Weight: 0.7 oz (20g) Bushing Or Bearing: Bushing Motor Type: 5-pole ferrite Connector Type: Z connector Gear Type: Metal
https://www.spektrumrc.com/Products/...odID=SPMSA4020
Originally posted by scootergenie View PostI would like to use Hitec if possible. on another note, I just ordered the Lightburner for this jet.... can't wait to try that out !
Considered one of the most powerful servos in the micro class, the HS-65 is offered with a choice of “shock resistant” Metal or “zero wear” Karbonite gears. The 65 series features a top-ball bearing for long life and positive centering, 31 ounces/inches of power at 6 volts and is an excellent choice for higher performance micro helicopters, electric park flyers, and 1/18 scale cars.
Originally posted by Aussie1 View Post
I have done many Freewing jets mods to micro turbine, and all have worked very well. Generally, a small turbine will not produce much more thrust than the EDF that it replaces, except in the case of the X45 , which is a game changer. This little powerhouse is smaller than my P20, but produces 11lbs of thrust, so I have de-rated it through the ECU software to about P20 power. I have read this thread and have adjusted all my rates as suggested, so expect a good maiden flight. One other recent conversion that I have done, was my F14 with a K30 in it, lot's of fun, and it sounds great in the air!! Here is a small video of doing some engine run tests. https://www.youtube.com/watch?v=tLXbpkuizjs
I flew the F35 today with the Admiral 600SP gyro turned on at about 9:00 position (pots) and it helps t slow speeds giving it the locked in feeling. But to be honest I think this jet feels locked in without the gyro. Its so much fun to fly and now with the gyro, high alpha landings are easier. photo showing the receiver installation post # 480
If you have the Admiral 600SP installed in your plane.... give it a try
Rich
Originally posted by RichJ53 View PostI flew the F35 today with the Admiral 600SP gyro turned on at about 9:00 position (pots) and it helps t slow speeds giving it the locked in feeling. But to be honest I think this jet feels locked in without the gyro. Its so much fun to fly and now with the gyro, high alpha landings are easier. photo showing the receiver installation post # 480
Rich
OK the second flight really didn't get off the ground it clipped the long grass along the edge of the strip and broke the elevator hinge and somehow we have been unable to find the nose cone so I have ordered new parts for them and I have also ordered a frsky S6R gyro receiver will be interesting as I have NEVER used one EVER before don't know how to set it up even we will see Ha Ha
Hi rsunleader .You be fine setting up the gyro but make sure you have it switch off when you take off then gain height ,then switch it on the gyro That is what I did and good job to ,I had the aileron switch on the wrong way and it went into a horrible spin ,just managed to switch the gyro of before it came in contact with mother earth and saved the model .Reset the gyro correctly and it fly a treat now .Alpha landing are a so easy with the gyro on
I'm looking for guidance with CG. I'm having trouble taking off from grass and I have had a few keyboard warriors tell me the CG is to far forward. When I asked them specific questions they admit they don't have this plane but it is "common knowledge". Geezzz
I'm in Kansas City which is 1000 feet above sea level and it is August, so it is hot. I know I need to be trying this on fresh cut grass on cooler days. I am using the Admiral 6S 4000 packs and I balanced at the forward edge of the plastic bit on the bottom of the wing as shown in earlier posts. I balanced right side up with the gear down.
Question 1 - Anything wrong with my balance technique?
Question 2 - How far back can I push the CG without getting in trouble with flight stability?
Any and all help with be appreciated.
Bob DeGood
Originally posted by fastforward View PostI'm looking for guidance with CG. I'm having trouble taking off from grass and I have had a few keyboard warriors tell me the CG is to far forward. When I asked them specific questions they admit they don't have this plane but it is "common knowledge". Geezzz
Bob DeGood
Here is the latest information provided by Motion RC in the support section of the product page:
As you can see, the revised CG from my manual and what's updated on the product page are very close. Unless your grass is like a golf green or is mowed prairie stubble, think you'll find it hopeless to take off. I only fly this plane now from a smooth surface (GeoTex).
If you've seen Stuart's video of his plane's mod's and his grass field, you'll also notice that his field is not very plush. I could have taken off at my old grass field, which was mowed prairie stubble - very rough and bouncy but much less resistance. In fact, the roughness and bumps would help bounce a plane like this into the air. I have the F-16 with the same power system as this plane and it could take off from that old field. I can't take off from the new grass field.
May I suggest trying a bungee launch instead of taking of from grass? Works like a charme and is a safe method.
I do have the same problem as the field of my club only has a grass runway which is not suitable for takeoffs of jets. So I do bungee launches and belly landings.
Regarding the CG, I do have it close to the recommend position (a little bit forward) shown in the previous post using a SLS 6S 5000 mAh battery.
Originally posted by Quax View PostMay I suggest trying a bungee launch instead of taking of from grass? Works like a charme and is a safe method.
