Adam1985 Hi Adam, the number of reports total less than a fraction of 1%, so, while of course the factory is always admonished to improve, it is always still prudent to test our flying machines because ultimately perfection is a responsibility better taken than delegated. If you're wary, give the retracts on this T-33 or any airplane for that matter a firm tug or two before maiden, or a brisk taxi, then recheck them before you actually lift off. I've seen people go to the extreme and purposely pop off the plates before maiden, and reglue them. Of course, energy needs to be transferred somewhere so I don't recommend relying solely on rock hard epoxy joints to keep the mounts in.... a rough landing just transfers the risk now to ripping out a chunk of foam to which the mount is glued.
I remember when ripped out foam chunks of F-86 mains glued too firmly to the mounting plate were increasing, and I remember when Yak-130s were shedding retracts during a brisk taxi alone with a nearly smooth glue-less foam face, so there is absolutely a balance to be struck.
I hope this helps!
I hope this helps!
