Originally posted by HaroldAnderson
View Post
You probably don't want to mix throttle to flap.
Because the issue isn't flap+throttle it's high speed+flap. Being high throttle doesn't necessarily mean high speed... imagine coming in for landing and needing a go-around and you punch the throttle and your flaps go up, or your flaps go up on takeoff instead of saying in takeoff mode.
Originally posted by janmb View Post
Which might very well be perfectly fine :D
The mount of nose heaviness these models are designed around is no longer just silly and sad, but outright dangerous.
Just the fact that they put a battery strap in the front bay is starting to seem ridiculous. They should have called it a reciever bay instead. I think the only reason mine balances ok is I put my rx next to the blue box, added the centerburner leds and have a 2s 800mah behind the cg point.
Originally posted by bandetx View PostYou probably don't want to mix throttle to flap.
flyAA,
I forgot the mention the CG thing too. Most of us are flying them 10mm behind the factory CG.
- Likes 2
Originally posted by Nickc2023 View PostJust the fact that they put a battery strap in the front bay is starting to seem ridiculous.
Hey, nice discussion. "don't use landing flaps at high speed". Hmm. Why would anyone DO that? I only use full flaps on final approach, after the model has begun to slow down.
Some other things that aren't particularly wise to do with RC planes:- don't turn off the transmitter if the plane is still turned on (or while its flying)
- don't look down to check your phone/zipper/transmitter while flying
- don't fly over the pits, or over football games, airports, etc.
Others here reported the same thing: the servos simply stopped working while flying normally. So we've figured out we shouldn't dive at 120mph with flaps out. But why are the servos shutting off in flight for no apparent reason? As opposed to a failure when under a large load, having both servos cut off during normal flight doesn't seem to have anything to do with the airframe. So I think there may be more than one problem here.Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
- Likes 8
Originally posted by themudduck View Post. But why are the servos shutting off in flight for no apparent reason? As opposed to a failure when under a large load, having both servos cut off during normal flight doesn't seem to have anything to do with the airframe. So I think there may be more than one problem here.
And as has been amply demonstrated, the design of the airframe DOES demand unusually high loads from the servos.
Has anyone checked their upgrade servos for travel as opposed to the stock ones? One of the upgrade servos I had in the kit was faulty as stated in my previous post this was replaced by MotionRC. EU. I have found that the stock servos have a limited travel the upgrade servos can travel 360% is this normal? I have never come across this in any other make of servo I have used.
I finally maidened my Mig today. Had 4 awesome flights. We had a nice 18C (64F) degree sunny day here in Canada today. Everybody came out!
What a fantastic jet! Wide flying envelope, rock solid, looks awesome in the air, slows down to a crawl and lands like a glider. I did some modifications to offload some of the stress from the elevators/FFS, and to accommodate for my heavy batteries (Admiral Carbon 5100mah 70C and Turnigy Graphene 65C) ~870g
Things I had done to my Mig:
- Upgraded elevator servos to Promodeler DS150CLHV
- Beefed up elevator rod, by inserting a PTFE tube inside the carbon tube, to fill the empty space
- CG 10-15mm aft of CG marks
- Flap/Aileron reflex (around 3mm)
- Removed 50-60g (at least) worth of unnecessary wires, moved the blue box all the way aft of the canopy bay.
- YEP 20A BEC. It comes with 2 output wires. Ran 1 wire into the RX and another into blue box. Should supply ample current where needed.
- Shortened the elevator extension wires (kept them the same gauge though). Tested the torque, by holding the elevator with my hand and moving the elevator control stick (on 5.1V). It moved the elevator and started bending the aluminum hinges, while the voltage stayed at 5.1. Very strong servos, even on 5V.
- Reduced mechanical travel on most control surfaces. Book suggestions results in excessive surface travel, and requires reducing the throws in the radio, which is far from ideal. Rudder and flaps definitely needed to go into more inner holes of the servo arms.
- Installed afterburners to help with CG
The jet was very stable in the air. I don't know if that's because the Promodeler servos center very well and are pretty tight (no deadband movement), or it's just the model's design, but I was very pleased with it's performance.
Can't wait to fly it again!
- Likes 6
Originally posted by themudduck View PostHey, nice discussion. "don't use landing flaps at high speed". Hmm. Why would anyone DO that? I only use full flaps on final approach, after the model has begun to slow down.
I love flying but to be honest I don't know too much about what goes into designing these aircraft. Why would a manufacturer choose to make the jet soooo nose heavy?
Which is to some extent true, they just overdo it - massivelyFreewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
- Likes 2
Originally posted by RedAlert View Postmy heavy batteries (Admiral Carbon 5100mah 70C and Turnigy Graphene 65C) ~870g
Like you, I've enjoyed great flights with mine, without any indication that something might go wrong. Of course, I've only had 6 flights in total and with winter's return, it's not likely I'll fly it again till spring. -2C here and just got back from flying my snow blower.
Originally posted by bandetx View PostTV nozzles will be good because they will add some redundancy for if the elevators fail.. You just have to leave them on 100% of the time!
Originally posted by xviper View PostBesides being able to put the top battery where the blue box was, do you think that it's the afterburner's weight that allowed you to balance this plane using those batteries? Those are quite heavy. I use the Gens Ace, which weighs in around the low 700's and I'm able to balance at 10mm aft of the marks. I'd like to use some of my heavier batteries but I doubt I'll be able to make it balance right. I will be getting the VT nozzles when they are available, hoping they will help with the balance when using heavier batteries and also to help out when and if my elevators don't do the trick in certain circumstances.
The way I see it only one of the batteries has a significant impact on CG, the aft battery is located almost at CG. My elevator servos are around 28g each, afterburners added another I believe 50g (and quite far back). Removing a lot of the wiring in the front, was another 50g or so. Moving the BB and RX all the way back helped as well. All of these combined, helped. And because I removed dead wiring, I wouldn't mind adding an ounce of led in the tail if I needed it to achieve good CG. I didn't add any led though. TV unit will certainly help with moving CG aft as well
