Originally posted by Airguardian View PostBeing enclosed may help in keeping the camera warm enough so that they don't shut-off mid-flight.
That would be a great way to puff the battery and shorten its life.
All - I have been monitoring and contributing to this thread for a while now and I have to say it is nice to start seeing more and more positive postings. Looks like the doom and gloom crowd is giving way to more excitment with this amazing model. This is definitely one of Freewing/MRC best designes!
it was a beautiful Sunday evening in Texas yesterday with a packed flying field. I flew the MiG for three hours non-stop, a quick picture attached.
I have to say I am starting to like the up angle thrust line which puts the model in high alpha at slower speed - it makes the landings amazing!
Good job Alpha !1 Photo
I know you have that problem janmb , I have run into it too!
Will likely test it out myself! :)
After some digging I found this for the Mobius. Understand there's a separate version for the Runcam.
May even end up doing my own version for a Firefly Q6! :)
This is an aerodynamic box to hold a Mobius ActionCam camera, for mounting on Freewing R/C aircraft weapons pylons. Or, any other object that has the mounting hardware (see notes below). The camera box is offered in TWO versions - one can be mounted under an attachment point, the other can be mounted above an attachment point. An additional two designs are available without the NACA cooling duct (the back of the box is open so cooling air flows through). The box is designed to snugly hold the camera without needing any additional hardware (the camera slides in). DESIGN IS BY GRATEFULFROG I also have a couple of pylons which can be used to extend the camera from the mounting surface, check my other thing files to find those.
Credit to themudduck !Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
Originally posted by fredmdbud View Post
They shouldn't be enclosed - that would block airflow over the heatsinks (exposed metal blocks in the Mobius, the screw-holes on the Mobius Mini).
That would be a great way to puff the battery and shorten its life.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
Originally posted by PaulZ View PostAll - I have been monitoring and contributing to this thread for a while now and I have to say it is nice to start seeing more and more positive postings. Looks like the doom and gloom crowd is giving way to more excitment with this amazing model. This is definitely one of Freewing/MRC best designes!
Good job Alpha !
The thrust line is such that once into the high alpha, deep stall, falling leaf realm, adding power only holds the nose up and keeps the alpha high...not recoverable. There is no response to any control input other than throttle.
Originally posted by kallend View Post
Be careful with that high alpha due to the thrust line, you can get into a deep stall. From a previous post by GliderGuy:
Originally posted by HK111 View PostGood to hear. For my initial hover tests, it makes things much harder - the plane really pitches up.
High time for thrust vectoring :-).
I actually like it because I can simply use throttle to control the angle of attack. I don't think this plane needs VT but that is all a personal choice.
I much prefer a neutrally balanced model that doesn't need neither up elevator nor up thrust line to fly stable high alpha. Which is exactly what my MiG will be once I get VT on it.
It definitely flies really well without VT as well, but not being able to push the limits properly in terms of high alpha (yet) is a bit of a bummer, and something I look forward to remedy.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
Originally posted by janmb View Post
The run cam doesn't have any. And some of us live in a climate where too much cooling is the problem, not too little
And a good number of us live where summers can get pretty hot - not enough cooling.
