View Post
RC30Flyer - LOL thanks for the correction.
Initially a lot of us discovered that flying with CG on the mark required 3-4 mm of trim vs the 1 mm shown in the manual. So I think “that” number became stuck in our heads as the “standard”. Oops!
Sorry for the confusion. I stand corrected and shall restate - “I balance 15 mm aft of the mark which reduced the trim amount from 3-4 mm to 1-2 mm which is CLOSER TO THE 1 mm shown in the manual.”
-GG
- Likes 2
Originally posted by janmb View Post
I typically do something similar, but primarily with rudder, not aileron.
Once established....If the nose starts to pitch up....increase bank angle (aileron or rudder) and if the nose begins to pitch down....decrease bank angle. The balance point speed is just right...not slow and not fast and seems to be constant or only slightly accelerating.
Thinking about this a bit more....I initiate the bank more like 10 ft vs 20 ft high. In other words, soon right after lift off.
-GG
The numbers of vectors (lift, thrust, weight, drag, centripetal force) being managed by tweaking bank angle with a positive pitch/climb angle is quite amazingly simple. The MiG does this so nicely.
Originally posted by fredmdbud View Post
From what I understand, it's the servoless retracts, not the servos and the LEDs, that cannot operate above 5V, and are thus the weak link.
Originally posted by Evan D View PostAs I said they use the MCBe in planes with the ESCs that contain internal BECs that produce 5.5V (I can send you pictures of the voltage readings) so it's not the MCBe, or LEDs that would have a problem. The servos are also the same as in many planes running 5.5V so they are also not the problem. The retracts in this are different than any others but doubt it can't handle 5.5V.
I'll just say the "rep" was saying what he thought is right or what he was told to say.
r.c. Castle website shows freewing servoless retracts 4.8 to 6v so maybe its the circuit in the blue box which takes the operating gear and feeds all other circuits that does not like more than 5v ? but if some of the freewing becs are rated at 5.5v then this does not make sense either ? any thoughts anybody ? https://www.rcgroups.com/forums/show...oless-retracts
MRC have been very clear on several occasions that the BB (MCBe) is prone to failure if running above stock voltage - which in most FW models is 5V, not 5.5
People who have asked directly about running 6V have been discouraged from doing so. One could obviously always argue that this has more to do with covering backs than the likelihood if it actually being a problem, but I for one will not be taking that chance.
Remember, these are CHEAP electronics. Have realistic expectations and play it safe imo.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
Well, you posted in a thread dedicated to the Mig 29 that you talked to a Motion rep that told you this. So what plane were you asking about when they said only 5V? There is no plane that uses the MCBe blue box and doesn't have retracts.
And you still are pursuing that the MCBe can't take 5.5V, why?
Originally posted by paulrkytek View Post
AH, take your point when I asked about the 5v/5.5v at MRC the model I was talking about at the time did not have servoless retracts
Originally posted by Evan D View PostWell, you posted in a thread dedicated to the Mig 29 that you talked to a Motion rep that told you this. So what plane were you asking about when they said only 5V? There is no plane that uses the MCBe blue box and doesn't have retracts.
sorry Evan my train of thought wandered from the mig29 to my 70mm F16 model where I am considering adding leds via a new spare blue box but I currently run 5.5v separate bec which works fine with existing servos and retracts which are rated at 4.8 to 6v but if leds are voltage sensitive then the circuit dedicated to leds in the blue box may not work if it was designed to have 5v input as opposed to 5.5v ( e.g blow the leds) which is why I also said in one of the posts that I err on the side of caution. I resolved the led issue on my F86 using leds rated at 5 to 7v range to add landing lights so my questions are basically information gathering exercises . The question is in the Mig 29 thread because I read different threads for my various models as some of the info is transferable to other planes I have in the Freewing range. Also I have not yet bought the Mig 29 so I am reading as much info as I can and asking as many questions as I can before deciding if to buy. Though I am beginning to think that the more I search and the more information I gather the less certain I become !!!
The low voltage LEDs will be fine on 5.5 through the MCBe or other blue boxes that have LED outputs. be careful with landing light out puts since they may blow regular LEDs.
I caution you with asking Motion (or other resellers) reps. So many people come on here saying they've been told things that are so very wrong.
Originally posted by Evan D View PostThe low voltage LEDs will be fine on 5.5 through the MCBe or other blue boxes that have LED outputs. be careful with landing light out puts since they may blow regular LEDs.
<nerd alert>
The active part of a LED is a semiconductor junction that typically needs between 2.5 and 3.5 volts to operate depending on wavelength (blue or white needs a higher voltage than red). This is a property of the semiconductor itself. It does not obey Ohm's law - a small increase in voltage leads to a LARGE increase in current which can easily blow the device. Brighter LEDs need, and can tolerate, higher currents but the voltage at the junction itself still depends on wavelength (Planck's law). For this reason some means of current limiting needs to be in the circuit. This can either be embedded in the lamp itself or in a separate controller. The cheapest way of doing this is with a resistor (which does obey Ohm's law) which is fine for operating from a very restricted voltage range (say 5 - 7 volts, or 12 - 15 volts for a LED strip). For operating from a larger voltage range, such as a 9 - 28 volt brake lamp bulb for cars and trucks, an active constant current source is used.
I have not taken a Blue Box apart but my guess is that in order to be cheap it simply uses resistors for current limiting which is why a restricted voltage range is specified. Since landing lights need higher currents in order to achieve the necessary brightness, the current limiting resistors will be lower in value. That is why you need to be careful which LED outputs you use for NAV lights as opposed to landing lights.
If you are adding non-stock LEDs to your model it is important to know whether they have built in current limiting, or need it in the driver circuit (controller/blue box).
</nerd alert>
Originally posted by Airguardian View PostOn the not-so-nerdy note:
I've blown LEDs myself by subjecting them to higher voltages than intended. They are out in a matter of seconds.
Originally posted by Evan D View PostThey use a small SMT, surface mount technology, 100ohm (from memory) resistor.
