Originally posted by mshagg
View Post
Originally posted by mshagg View PostAnything other than "they're awaiting stock" should be discounted as unfounded speculation. That includes hearsay suggesting they're doing testing, considering revisions to the design or witholding the jet from sale due to feedback, as we have heard from unverified sources.
If help desk staff are confusing the message as has been suggested, Motion might consider tidying up the communications around the model and ensure advice provided to customers is consistent with the official position. Along with the usual rumour mill stuff there are actors who are happy to promote the speculation as fact to the extent it suits their (negative) narrative about Motion/Freewing.
I’ve only ever known MRC to do right by us ALL, including information being handed down. Just gotta wait it out to see what comes down the pipeline. Customer Service may not always be in-the-know of the internals of company decisions.
Keep em’ flying!
Originally posted by Evan D View PostFred was talking about the Yak when he said discontinued and I think Wolf thought
he was talking about the MiG. From what I was told FreeWing asked retailers to hold sales pending
an investigation, a big difference to being discontinued.
Either way it would be good to know what’s really happening and not second hand info.
Thanks Shaun. :)
If you are to try flying the MiG slow, particularly in high alpha, either install TV nozzles or do at 5 mistakes high (As opposed to the usual 3 I recommend, lol).
The jet will bite you if it caughts you off guard with the high alpha lock and it requires fast, usually counter-intuitive action on the pilot's end to get out.
'Snappy' maneuvers are safer to execute in general terms. Going straight into high alpha is going to get you high-alpha locked rather sooner than later with almost all certainty.
This said, you can probably try doing the same in inverted flight without any such danger. The plane is super stable in inverted flight, rudders retain full authority and the off-thrustline conspires with the jet to pull you out of it just by adding throttle. Again, I'd recommend doing so only at a safe, conservative altitude. :)
What exactly is this "alpha lock" mentioned? I'm assuming it actually means "alpha non-control", because after stall the nose will at some point drop as the plane enters into descent (without TV). Every other mention of "alpha lock" I can find refers to flight surface retraction limits (e.g. slat position) at high AoA.
I came across this while executing a turn too tightly (CG set back10mm aft) - the plane pitched up into a stall, nose drops, but when thrust reapplied with nose level there wasn't airflow over the wings and tails, so pitch up. Rinse and repeat until the plane was allowed to recover enough forward motion to re-establish lift and balanced forces.
Thanks for the tips. I've got a bit more confidence in the general habits of the airframe itself after watching all of the available YouTube on it. Mine has a Kingtech K-55 on it, so I don't have the instant thrust to help get out of trouble, so I'll definitely keep it high. My first flight after moving the CG back (too far) was nearly disastrous. With my extremely heavy wheels, the aft shift of the CG for landing was a mess. I made two missed-approaches and finally stalled her on the last one. She pitched straight up started tail-sliding to the ground. Luckily, the 5' tall weeds at the approach end of the runway (that were supposed to be trimmed the day before) broke her fall and she didn't suffer a single scratch or dent. The next two flights (after moving stuff around to take the CG back to near-nominal) were pretty good, but I didn't do much with her up there. The engine thrust line is OK because I get no trim changes in the pitch axis with throttle movement, but my inverted flight requires TOO MUCH down to maintain. Even then, it maintains attitude but still loses altitude. I'm still messing with the reflex and CG, but the heavy wheels are really biting me in the ass. Even 20mm aft from the factory marks is nose-heavy once those heavy wheels swing forward :(
Since you have the K-55 in there you may observe a totally different behaviour in high alpha handling since the 'lock' is mostly due to the thrustline keeping the nose up and overpowering stalled stabs. If your thrustline is more neutral, this may no longer be as relevant for you, but maybe you thrustline is still just as bad (likely, If I am to judge by your description of inverted flight), so be careful.
Originally posted by fredmdbud View PostWhat exactly is this "alpha lock" mentioned? I'm assuming it actually means "alpha non-responsiveness", because after stall the nose will at some point drop as the plane enters into descent (without TV). Every other mention of "alpha lock" I can find refers to flight surface retraction limits (e.g. slat position) at high AoA ...
As soon as you detect this trend developing, one should cut throttle immediately and push jet down, starting with a fast full-pitch-down flick, followed by just slow nose-down pressure until nose drops and SLOWLY start adding throttle as the jet regains speed. Jamming throttle wide open in this condition will force the nose up again.
Even with this in mind, I have found myself a couple of times where no throttle-recovery was taking too long.
In these more extreme scenarios, sometimes a quick throttle impulse can help break the pattern, or adding full counter roll/yaw inputs to force a spin that may send the nose into the ground too. If you are flying high, you have a few seconds to experiment with different alternatives. If you are low and your first one or two attempts don't break the jet free, chances are you are bound to eat the ground.
Airguardian,
Remember when I said I was inspired? Well, I took the MiG out today and Cobra'd her! She got mushy in the recovery, but it looked a lot like yours from a distance. Right after that, I did it again with a flip! I think I've got the CG dialed in, and added a tiny bit more down-thrust on the engine. Now she inverts much better and the rolls are almost axial. Fun!
Originally posted by Evan D View PostYou’ve been here awhile and have seen my posts, right? FW asked the resellers to not sell what they have pending an investigation into redesigning the rear end.
I've been told the “out of stock” is almost over...
