I apologize for posting this again, but imho... I still see this as less than stellar engineering of the voltage used to power the system, including inadequate wiring in long runs. The retracts are the root cause as they can only be operated at less than 6V (5.1V optimal). These limit what the blue box can handle and any connected servos as well. I separated and run all flight controls from an 8.4V LiPo with heavier extentions, better servos. I isolated the bec and the blue box on 5.1V only running retracts and lights. I can load up the system with full flaps, full throttle, gear, and lights with no sign of low servo power. Balanced tailerons, carbon pushrods, better ball links round it all out. Stiffen foam if you feel it needs it. There's also the issue of non-scale taileron pivot points that increase aerodynamic loads back there dramatically. Angled back and aerodynamically centered pivots as on the full-size reduce the loading to the servos had they chose to incorporate. AND, the misaligned thrust angle, which I'm currently trying to get back to work on and correct. (Sometimes life gets in the way!) Can't wait to get back to it.
To correct all these issues at the factory would increase the price as it is now. Most of these don't need to be addressed and can be flown with pilot care, knowing the different idiosyncrasies. I say this as many 29s are still flying basically stock. More power to ya! I put it to each owner that "it is what it is" and to solve the problems in his own way (not necessarily mine). For the most part, the jet is certainly flyable and looks great.
As these foam jets have gotten bigger, heavier, and faster, the loads increase. It's a no brainer. You won't catch many turbine guys running low power stuff or inadequate set-ups... at least not for long!
