bye
It seems that a picture (or video in this case) is worth a thousand words. Those stabs really flex at full throttle and flaps!Hugh "Wildman" Wiedman
Originally posted by fredmdbud View Post
The video shows why my first flights with the original 17g servos didn’t have issues…..I flew it like a grandpa: 1/2 throttle and no flaps until slowed on down wind after the gear was down. Faster flying was only done after upgrading the FFS servos.
-GG
So very strong evidence of an aeroelasticity problem that may be overcome by brute force.
A more elegant solution would be a redesign of the stab pivot geometry and mountings to reduce the flexing forces and increase the structural stiffness.
In my opinion (which is unchanged since last year).
- Likes 2
Originally posted by Evan D View PostI'm unsubscribing from this and the thread in RCG. Nothing but the same ol same ol...
Originally posted by kallend View Post
Brute force is a Band-Aid fix.
Or just widen the flap span - they're not molded on the wings, and are an easy DIY project (balsa).
But probably not good enough for you, so just don't buy it (which I suspect is the case).
Originally posted by fredmdbud View PostA Band-Aid fix today is better than a redesign years away.
Glass the stabs with a continuous ligthtweight cloth (WBPU will do), closing the profile.
Reinforce stab assemblies (easier way to do is by epoxying in the verticals).
Add some stronger servos too. Use a proper linkage. Shift CG aft, 15mm minimum, reflex airfoils. Boom, done.
This is what my honest trader in China tells me regarding upgrades...
"Hi thank you for your reply. Yes, the elevator servos are 30g now. Thank you.
However, the Mig29 in our stock has 23g elevator servos. And after the stock is sold out, we will have Mig29 with 30g elevator servos. At the same time, we will try to buy 30g servos from Freewing if they have it now. If we get 30g servos, we can replace the servos for you as well. Thank you.
My plan is to fit a pair of CF rods in the underside of each stab and as a belt and braces fix get on my knees and pray for a week before maiden. Having plenty butt puckering flights with the Freewing F4 to worry about what happens when the Mig arrives!
Originally posted by locharrow View PostThis is what my honest trader in China tells me regarding upgrades...
Will be interesting to see the specs of the servos the Freewing factory will start installing.
Originally posted by fredmdbud View PostThen prove/demonstrate it?
Thanks Fredmdbud for the videos..
Band aid fixes work good enough via demonstrated success. For sure I DO NOT fly fast with flaps down and have no desire to push the flight envelope into that realm of no man’s land.
Happily pushing well past 1,000 flights and still going strong courtesy of multiple band aid fixes. The main one I did not do was glass the FFSs. But, that’s my choice. So far, one aileron and one rudder servo needed to be replaced (they started to chatter) just to be on the safe side.
By my count, I did 15 band aid mods suggested by the group think or discovered on my own (like beef up the main gear attachments and adding RF chokes). Many of the mods were likely not needed, but were implemented during the early phase of this forum when the real cause of the crashes was unknown. None were hard to do.
I love this EDF!
-GG
Aside: Some of you in the past have asked how well the batteries have held up. The Admiral Pro 6000 50C batteries put into service 04/2020 have finally started to show signs of their 14-month age. All have a very slight puffing and the internal resistance readings are starting to creep up. Time to spend some $$$. They've supported a large number of flights with the AL37, F-4 and MiG. I got my money's worth outa these (charged at 4.5 amps, consumed about 4000 mAh with a typical flight profile, never charged below a 50F outside air temp, no cool down after a flight...put them right back on charge upon landing).
Happily pushing past 1,000 flights and going strong courtesy of multiple band aid fixes. The main one I did not do was glass the FFSs. But, that’s my choice.
By my count, I did 15 band aid mods suggested by the group think or discovered on my own (like beef up the main gear attachments and adding RF chokes). Many are likely not needed but were implemented during the early phase of this forum when the real cause of the crashes was unknown. None were hard to do.
I love this EDF!
-GG
That's astonishing! Between this plane and your AL-37, how do you find the time to fly so much and are your thumbs worn down?
Something must be working for you but perhaps the only one that really made the difference was NOT flying fast with flaps down.
