  • Thanks, I did see that one. Looks like a decent mod if you do have nose gear issues. I've made no mod to mains or nose on mine but I fly off pavement and the MiG lands very smooth.
      Our runway has very short grass, Mig it is all ready to go, I will see how it lands before doing any mod to the undercarriage.
      • It's funny.... everyone complains about nose gear problems but I haven't had a single nose gear issue in over 200 flights... hard landings and crashes included.
        All my landing gear problems have been related to the main LGs' mounts (or rather, the weak foam that they mount on to).
        • Same here, no problems with nose or mains with mine. But also, with all the landings I've done I have only tipped mine and scrapped a wing tip once with all the flights, also close to 200, I've done. I still think the big MiG is the most stable landing plane I have. Even cross winds have little effect.
          • Ditto - No nose gear mounting issues. Replaced a faulty nose gear servo is all.
            Although I didn’t operate on grass before I lost her. Problems with the main wheels only due to the softening of the foam in the mount areas and one eventual main gear plastic mount replacement when a crack developed.
            Only this problem area as she pushed way, way beyond 200 flights. I wore out a few main gear servos. They would eventually stop retracting fully.
            -GG
            • Just got my Mig-29 today and was wondering what kind of stand you guys use to attach the wings on the airfield. Turning the aeroplane upside down - which stand works nicely?
              • Originally posted by JetFun View Post
                I don't use a stand or turn the plane upside down to install the wings. I put the plane right side up on the set up table with one side at the edge of the table - install the wing on that side and turn the screws from below. Turn the plane around so the other side overhangs the table and install that wing - put the screws in from below. Sometimes, simple is the best way.
                  I use a stand from Harbor Freight, cost $21, that holds up to 200 pounds. Actually works great for my SU-30, A-10 and a bunch of others. The only problem is that when I take it to the field, my buddy who also has a Mig and many others, he's always hogging my stand!
                  Click image for larger version  Name:	image_17304.jpg Views:	0 Size:	34.3 KB ID:	350037
                  • The Harbor Freight stand is nice cause in folds flat for transport and can be adjusted to any width. Also, it's at the right height to work on an aircraft without bending over. Also works for my Beast BiPlane, the F-18's and F-4's and the B-24's, anything with a flat bottom. I also have a couple Robart stands, but they break too easy and are more for smaller planes. Extreme Flight makes a great stand (pictured below) but it's pricy and doesn't travel well. The other great stand I have I made out of PVC (also pictured below). It comes apart for easy transport and is great for the Corsair, Spitfire, FW-`90, P-51, F-16, Stinger 90 and the Avanti, as well as the F-4 inverted. Easy to make and the price is right! I usually take the Harbor Freight and homemade stand to the field and both pretty much handle everything I've got.
ID:	350039Click image for larger version
                    • Thanks for that feedback on your stands!
                      Just figured out that the ailerons are on just one channel out of the blue box. Would have liked to put the ailerons, elevators and flaps on separate channels on a Hott GR-32 receiver. Seems that's not possible without reconnecting thoses wires to servo connectors and skipping the blue box. Especially for trimming it would be helpful to have all on separate channels. Added the Thrust vectoring. Having snapflap on ailerons aswell would be helpful when doing tight TV stuff.
                      I am fine with the gears running via blue box although the doors and gears take a lot of time.
                      How did you solve this or did you just go with the stock setup? Not sure if it's worth all that effort.
                      • Sorry, double posted.
                        • Ok, went for the fast option. Just two servo cables (aileron and flaps) out of the wing past the plug with door servo and light. Might solder a better solution when time available.
                          • I only use the blue box for the flaps, lights, and undercarriage.
                            • I typically use a Freewing Su-35 packaging foam as a 'stand' for all my jets when I'm working on them at home. :)
                              • First flights today.
                                Very mixed feelings.
                                I had to trim the flaps and ailerons up quite a bit. But that's OK.
                                Flew 6s SLS 5000mAH and 4000mAh. The 5000mAH are 690grams each. The 4000mAh are 605grams each.
                                Ended up three times stuck in High-Alpha. First time when I really slowed down and then wanted to accelerate out of a turn. Lost quite some height hovering coming down vertically - like hovering /harrier a 3d aeroplane. Stopped engines - nose down - but when accelerating out obviously pulled to much and ended in another High Alpha. Lost like 20 meters of height. Anyway the vectors did the trick. Luckily I had installed the Vector Thrust and did a full pull flip to get out of it. Same thing happended again when I slowed down to check stalling characteristics. This time used VT right away.
                                First flight, stuck twice in High-Alpha.
                                First time I was level, full power and pulled - then got stuck in High Alpha.
                                And then again while playing aroud a bit. Nose down and level full power saved it. Luckily it does not stall over a wingtip but rather dips the nose.
                                That is a very nasty characteristic to not get out of High Alpha. The Mig-29 is simply underpowered. It is what it is. I wish those things would be shown official videos. Think I need other EDFs. Could get nasty if you come in landing, see there is not enough space and need a go-around. That plane has virtually no chance of survival if it is stuck in High Alpha. Even VT would just get the nose up during landing and then not be able to accelerate upwards.
                                Happy I did not try the first flight on the very heavy CNHL 6000 mAh 6s.
                                Just think it needs to be said. If I would not have had VT I don't think I would have saved the plane the first time. The grey color in the evening was an extra handycap. Simply did not expect the aeroplane to get stuck when trying to accelerate upward from slow speed.
                                Otherwise it's lighter than two Avanti but has two of those powerplants. If at speed the EDFs get a nice grip of the air and verticals are pretty OK. If at speed the powerplant is enough to have fun. Would not expect that kind of "stuck-in-High-Alpha" with the power it has accelerating from half power to full power. The EDFs just don't grip enough at low speed. The same powerplant grips nicely in the Avanti at low speed. Not sure why but I guess the Avanti is just more aerodynamic.
                                Guess most of you know this MIG-29-High-Alpha thing. But I simply have not read too much about the MIG-29. Just looked nice on the videos. The vertical harrier was really beautiful. Very nice for a jet. Just not when you are trying to save the plane not knowing what went wrong. First thought was if I had somehow programmed some switch by mistake, then hit it and the VT were going into full up mode. Lost a lot of height because of wrong thinking.
                                Beautiful aeroplane though. High Alpha looks beautiful during landing.
                                Has anyone tried the FMS 80mm EDFs? Will the 100 Amp ESC be enough? My amperemeter stops at 100AMPs.
                                • Hi JF,
                                  Lots in this forum to read about high alpha. Well explored. AirGuardian is the champ of exercising the MiG and a at high alpha entry/recovery. Watch his videos.
                                  VT is the answer. I never felt she was under powered on 6000 mAh.
                                  LOL - I didn’t install VT, eventually lost her to high alpha lock down low but only after 2000+ flights!
                                  I REALLY liked to fly the MiG-29!
                                  -GG
                                  • Is the High Alpha problem solved with the FMS 80mm EDFs? I mean at least to be able to accelerate out of High Alpha. Actually I wanted the MIG-29 for some close to ground aerobatics. Just seems now like the fun stuff can only be done with enough altitude. I have flown many years of 3D propeller aeroplanes and the fun is always close to the ground.
                                    So I am just wondering what the best route is.
                                    • This video shows what the MiG-29 is capable of
                                      https://www.hobbysquawk.com/forum/rc...967#post348967
                                      3D flying, in my opinion, is a NO….especially close to the ground. I am unaware of any EDF solution that will allow acceleration out of alpha lock. Doing that may require a gas turbine.
                                      Obviously the video shows you can get out of alpha lock with VT pushing the nose down. But a pure “acceleration” out of alpha lock without lowering the nose….hmmmm….gas turbine power required is my guess. Others may have a different opinion.
                                      -GG
                                      • I agree. The big MiG can do some awesome things, has a great presence in the air and is one of the smoothest landing planes I have (especially in wind) but it has a problem and thrust isn't the solution. The TVs can get you out of alpha lock but I've never gotten to the point that I'll do a very low altitude flip or snap.
                                          BINGO!
                                          Back when this plane was brand new, before the TV nozzles were even available, several crashes occurred in SE Asian - with videos. It was blamed on flying at high speed with the flaps deployed. First, why would anyone do that anyway? No matter. That was the assumption at the time. Before I got my VT nozzles, I did some tests to see what would happen if I slammed the flaps down at speed and see if the thing would fall out of the sky. This did NOT happen. Nevertheless, (form my other Mig experience) I did not try high alpha until I got the nozzles on and yes, even with the nozzles, it was hard to get out of high alpha because this plane is big and heavy and doesn't have the thrust to weight ratio to do it comfortably. Altitude is your friend and if you're not good at this sort of flying don't do it down low where you won't have the planning or the skill to get out of it in time.
                                          Without VT nozzles, this plane simply high alphas itself into the ground (or in this example at my field, full power into a lake). VT would have likely saved it.
                                          Yesterday, I flew my SebArt (Freewing) Mig29. It is only a 4s plane, very light, has VT nozzles and has the thrust to take off vertically out of my hand. This plane can high alpha for the whole battery a couple feet off the ground, no problem. It can even hover in place (if I was skilled enough, which I'm not). It has the power/weight ratio to lift the tail (it doesn't really "drop the nose") and start to fly "normal" again. The Freewing 80mm Mig29 DOES NOT. You'd need an extra 0.5 to 1.0 kg of thrust to do it and then your flight time goes down to a couple of minutes or less. You can increase the thrust, but it's hard to increase the battery capacity without some major interior redesign. But then, you're adding weight back on for that, require extra thrust to push it around.
