I have been coming back to the Mig-29 since the pre-order came out ordered yesterday hope I am not too late for the first batch.
Here is another picture with more size info for decals. I put a side view at the same scale and it looks to me like the vertical stab roundel should be around the same size as the smaller of the two example wing roundels. Also I indicated some other boxes in the drawing, but some are specific to this DPRK livery. The dimension on the 3 digit number on the intake is the size of a rectangle bounding all 3 digits. Sorry for the spam, I tried to replace the drawing several posts ago, but apparently "edit" does not allow different attachments.
Originally posted by raron455 View PostDoes anyone know the actual main wheel size???? I pre-ordered mine, I have been reading this post and have read everything from 65mm to 80mm. also the actual AXLE size 4mm 5mm I want to go ahead and get a set of brakes for this, but don't know what size to get. Any help will be appreciated
Originally posted by PaulZ View PostNow that we know the axle sizes what break/wheels are you all looking at? I am thinking of using the JP Hobby ones but they are 65mm wheel diameter. Anyone found larger wheels with breaks that don't weigh as much as a battery pack? LoL!
Originally posted by dsmithwc04@yahoo.com View PostI thought it was interesting that the 5100 batts had same flight time 5:30+ and active throttle ~4:00 as the 6000 batts. Must have reached the depreciating returns on weight to power. Since I plan on running 5000s this isn’t bad new at all.
Originally posted by Gordon View PostI know I will get laughed out of town for asking this, but could you fit three batteries, say 4000s into the Mig and would it give extra flight duration ?
what do you think Alpha ?Pat
Originally posted by crxmanpat View PostI'm sure 3 batteries would fit in the bay at one time, but you'd be adding a ton of weight to the tail to get it to balance. You'd also be hard pressed to find room for the BB and you RX.
Originally posted by James View Post
Interestingly enough, there is a great amount of space on the sides of the back battery compartment. We have our receiver tucked in there with plenty of room and the eagle gyro is under the back battery compartment. So you could totally fit the blue box back there and your RX / gyro and have the entire top/middle compartment clear if you wished. Might just need a few extensions for the nose gear and steering.
But...three 4000's up front? CG would be impossible to achieve without adding a tone of tail weight. Although I'd love to see someone prove me wrong.Pat
Originally posted by crxmanpat View PostWow, this thing has way more room than I thought!
