Originally posted by T-CAT
View Post
Originally posted by Alpha View Post
Thanks for the clarification on the nose gear Alpha! However being a scale nut i can't leave well enough alone lol. I'm looking forward to getting this in my hands and really seeing what she can do. It will likely get refinished but not right away. Hey Jlamb low level high alpha formation down the runway!
- Likes 3
Originally posted by JLambCWU View Post
https://www.rcgroups.com/forums/show...DF-afterburner
Originally posted by kallend View Post
Or you can make your own DIY afterburner for far less $$ and lower drag.
FW F-14 and F-16
The Centerburner doesn’t slow them down nor does it reduce the acceleration and takeoff roll 👍🏼
Originally posted by FlyBoy90803 View PostWould this jet work properly with the AR637T DSMX 6-Channel AS3X Telemetry Receiver?
I believe you can have it in the scale location it will just have to retract forward. I’m sure Alpha will speak to this at some point.
From my observation grass field ops is one of the biggest reasons.
The jet at the scale location would also be much easier to wing tip while taxing at high speeds.
I plan on modifying mine as I fly from nice asphalt runways.
Literally just pull out the mounting block and remount with a support plate at the back of the bay. Put in a longer steering arm. Reverse the strut on the retract peg.
Stock gear door closures may even work in their current place.
If it worked well in the scale location it would have been put there, so it obviously doesn’t.
That is the great thing about this community though is all of the modifications that people are able to achieve!AMA 424553
Originally posted by RRHandy View Post
Unless you're something I'm not, The gear retracts rearward now and you are saying you are going to have it retract forward?
Short answer: They already did and settled with this not-so-scale layout because placing the nose gear on the scale spot makes this jet extremely prone to tipping over. More so than the Freewing Eurofighter for those that may have had one, so there's that. Now if you still want to do it, do at own risk and know what to expect! ;)
