KevinMar Your Gripen looks badass!
Originally posted by SanExup View PostAirguardian What I mean is like any man and machine interface, for lack of better terminology, the mind meld with the plane. And yes, maybe some level of feedback in the vortices displayed in the smoke. Maybe?
The tighter and more accurate the feedback loop the better it "feels".
I have a few planes that "feel" really good, and others where the "feel" is rather sloppy.
I finally got some lighter batteries, ZEEE 4000, and it is fun to fly the Gripen with them! Initially I was only flying with 1 lb 12 oz Thunder Power 5000 packs all the way aft and 100g lead on the tail, 4 minute flights. The 4000 packs are much lighter and more fun to fly, losing 30 seconds of flight time is a worthy trade off IMHO, I may slide that 4000 all the way back and lose as much lead in the tail as possible, and regain even more performance. Honestly, I don't find it to be too bad as it is but lighter is better applies especially on this plane.
I also installed a gyro and I'm finding it to be very sensitive to gain, meaning about the point the gain is high enough to stop the wings from rocking I run into problems at high speed because of too much gain! I'll get it sorted hopefully, or just put up with a bit of wing rock at a lower gain. Also it could really use a speed sensing gain adjustment. The gyro I put in here is overkill really (iGyro SAT) but it has a crazy amount of adjustment potential. Some of these MRC EDF jets don't need gyros and some lock in completely with gyros but this one is a bit like my 90mm F-104, it may never be perfect.
Originally posted by Husafreak View PostI also installed a gyro and I'm finding it to be very sensitive to gain, meaning about the point the gain is high enough to stop the wings from rocking I run into problems at high speed because of too much gain! I'll get it sorted hopefully, or just put up with a bit of wing rock at a lower gain. Also it could really use a speed sensing gain adjustment. The gyro I put in here is overkill really (iGyro SAT) but it has a crazy amount of adjustment potential.
The only good solution to that is, as you are already thinking, is IAS input that automatically adjusts the gain. I believe the iGyro actually supports that internally.
For my part, I will be using a standalone IAS and program gain adjustment based on telemetry value from the radio.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
Before the TVs my Gripen was flying awesome. After I put them on it was still awesome. I did turn the pitch mix down a slight bit but it tracked perfect and had no change in pitch with or off throttle. The only down side was I was going through the battery much faster.
Later last week I went back and cut the nozzle foam and put on the plastic nozzle from the old rear fuselage. I also redid the centering of the TV servos and up’ed the yaw rate.
When I flew it Sunday it was horrible. Flew very nervous and would come out of a pitch flip tilted. Also it dove on throttle and pitched up off. A turn of the ball link fixed the pitch issue and moving the CG forward 3mm calmed the twitching.
Lookin at the TV on the bench maybe glueing the plastic nozzle may have changed the exit just a little. I re centered as best I could and have 8 sets of batteries for today.
Mo better. A tweak here a tweak there and pushed the battery back to the more tail heavy spot and all’s well. Surprisingly even one turn of the yaw ball link on the TV makes a lot of difference in feel. As I’ve said before the new TV ball has a lot more authority than previous FW TVs.
And yaw really effects roll...
Originally posted by Evan D View PostAs I’ve said before the new TV ball has a lot more authority than previous FW TVs.
A perceived experience of this VT having more authority, if at all correct, is probably more down to the rest of the airframe than the VT unit itself.
Originally posted by Evan D View PostAnd yaw really effects roll...
Originally posted by kallend View PostWell, I haven't flown all aircraft, or even 99% of them, but I think that may be an overestimate based on my experience, both full size and model.
Forcing an aircraft to yaw means the inner wing flying slightly slower than the outer wing, which in turn means the inner wing generating less lift than the outer one. Which in turn means that the yaw you commanded also causes roll in the same direction.
It is hard to imagine an aircraft with a geometry that has none of that coupling, nor have I ever encountered one yet.
Originally posted by janmb View Post
Obviously neither have I, but it is a matter of fairly basic physics causing this.
Originally posted by kallend View PostPerhaps you've not flown a competition level pattern plane.
In general you wouldn't notice it much there at all since F3A and similar are flown in the vertical only plane, so you don't do any yawing in wings level orientation at all anyway. But if you try, you will learn that these models follow the laws of physics too.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
Originally posted by janmb View PostIt is hard to imagine an aircraft with a geometry that has none of that coupling, nor have I ever encountered one yet.
I'm curious as to how the Su-57 would react in that regard, since the way the vertical stabs are canted means they must geometrically generate a fair amount of 'opposite-roll' moment when applying yaw, potentially compensating part of the aerodynamically-coupled, yaw-induced roll. :)Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
- 1 like
When I stated that yaw really effects roll in my earlier post I want to clarify that I meant during high alpha or very low/ zero airspeed Using the yaw TV really effects roll. And not necessarily in a bad way, you can do some neat things with it.
I also said way back after my first TV flights with the Gripen to be careful using a lot of yaw TV input because the plane will do a quick corkscrew and end up pointed straight down and to play with it at altitude.
Originally posted by Evan D View PostBefore the TVs my Gripen was flying awesome. After I put them on it was still awesome. I did turn the pitch mix down a slight bit but it tracked perfect and had no change in pitch with or off throttle. The only down side was I was going through the battery much faster.
- 1 like
Been waiting for Gripen to come back in stock in the European Warehouse since November. Not Freewing or Motion RC fault just one of those things. While I have been waiting for the Gripen to come back in stock it has got me thinking. The FMS Rafle is due out soon and this has a more powerful motor in the model. Mmmm should I go for that. I do not think anyone has one yet because they are not avaliable yet. But it got me thinking 🤔
The aircraft are sufficiently different that, to me, one does not substitute for the other. That said there are things about this specific rendition of the Rafale I like (there are others I don't). As far as the more powerful motor, I think you have to look big picture and think about the aircrafts weight and the ducting losses of a bifurcated exhaust versus the Gripens clean single. But it's a good thing to be thinking about.
Just been study the Rafale and like Evan D states, there are thinks that are good about the Rafale and some that are not so good. The one thing the Rafale does not have is the Motion RC Customer Service and that is a big factor to me. So I think I wait until the Gripen is back in stock.Looks like we are going to be in this Lockdown until the spring so there is no hurry and I am sure the Gripen will back in stock by the spring 😊
I did add, and then removed, that the one big thing I personally don't like is that it's FMS and distributed for us in the US by HH. In general I like FMS (and EFlite) but there are certain design things I think FW does better. I do hold a grudge about HH and their marketing department and to some extent customer service. The grudge is mostly that they used to be so awesome and now just aren't.
Since Hobby Zone sells it, I'll probably buy one from them.
But that said FW and Motion aren't perfect either. As some say it's a first world problem.
- 1 like
Originally posted by Captain Moron View PostBeen waiting for Gripen to come back in stock in the European Warehouse since November. Not Freewing or Motion RC fault just one of those things. While I have been waiting for the Gripen to come back in stock it has got me thinking. The FMS Rafle is due out soon and this has a more powerful motor in the model. Mmmm should I go for that. I do not think anyone has one yet because they are not avaliable yet. But it got me thinking 🤔
