You certainly don't need the BB.
Just take the time to properly learn how to navigate the menus of your Tx, knowing what everything does and then it shouldn't be difficult to implement the mixes for this one. Literally only needs a delta mix to the elevons and pitch being fed to the canards (No need to feed them roll, really, and it's not even scale if you do so). ;)
Originally posted by Evan D View PostRay should have his file from when he flew his with his DX-9. His has AS3X.
My set up doesn’t have AS3X… maybe get Rays file. If you want mine give me your email address.
Originally posted by Evan D View Post1- Welcome!
2- Where in NC?
q1- yes, there is no MCBE in this. There is a lighting module, plug each surface in its own channel and mix. I can send a spm file
q2- yes, search MCBE, but you don't need it
q3- no
again welcome
Thanks Kallend, I've seen your post and followed your print out before I posted my question here, and it didn't seem to work out for me. I don't know if im just doing something wrong or if theres something wrong with my jet or radio.
Thanks, again guys
Originally posted by reemo_2001 View PostGreetings from NC, newb here and I have a question about the Gripen. So I purchased a used Gripen from a local guy and I'm having a time trying to get this thing set up correctly. I've watched the "mixing" video on youtube from Motoion RC and the spektrum "forward programming" videos as well. I noticed my old freewing f22 had a blue box inside and wondered if the Gripen should have one as well so I ask a few local guys who confirmed there is in fact a blue box inside when purchased new. when i setup my radio it doesn't allow me to add flight modes to a switch, and if I do, then one of the canards moves its position away from center.
OK so here goes my questions.
1. Can I still setup the jet without the blue box? If so then how?
2. Can purchase the blue box with wiring from Motion? I didn't see it listed under spares for the Gripen.
3. Does anyone know if the replacement fuselage come pre-wired with the blue box and wires?
Here's my setup:
spektrum DX8 G2
Spektrum AR8360T receiver
I have the elevon/canard mixed per the Motion RC video
I have the forward programming per the spektrum videos.
I've been at this for 2 weeks now, SOMEONE PLEASE HELP LOL!
Thanks in advance.
1- Welcome!
2- Where in NC?
q3- no
again welcome
Here's my setup:
spektrum DX8 G2
Thanks in advance.
Originally posted by BenOzzy94 View PostWell it seems the consensus is lighter weight is better than more thrust. I have found a link to the new X-fly galaxy fan and motor combo which seems to promise a little too much but I might get one and see what it does to the performance of the jet.
Consider it a mini review of sorts to see does the 3.4kg of thrust with a 6S lipo really add up.
Originally posted by Airguardian View PostSick!
What flight times do you get?
Have you added cheater holes?
What's the exact EDF + motor+ ESC + battery combination if I may ask? :)
Fan Midi Evo 90 1600kv Motor Tunrigy 36..?? something and 110Amps peak.
A great Combo very light setup and lots of power.
cheers Rico
Sick!
Hey guys
Just wanted to share some shorts my pals Freewing 90mm conversion to 8s . It really moves. I also added some shorts videos from a dronechase.
Full video will follow on my channel.
Greets Rico
https://youtube.com/shorts/hI_eUelvkdA?feature=share
