  • The canards in roll don’t add much to the rate but I think they add to the quality of the roll, it looks better.
    I don’t use gyros so can’t add to the second part but sounds like a good idea to try.
    • Originally posted by Rcfiddy1 View Post
      The question is this, Should canards be used in roll and elevator or just elevator?
      Depends on who you ask apparently.
      If you want the jet to fly scale-ish, then only pitch, and ideally with a gyro controlling the canards (also only in pitch) and CG shifted aft.
      Also, I see people say the gyro gain causes oscillations at high speed
      Only in the roll axis that I have noticed.
      so I mixed my gain with the throttle so it will drop the gain value as the throttle increases.
      It may work but you may have conditions with high speed and no throttle (such as a loop, dive, or sudden powering off) so I'd strongly advise against that.
        . . . . so I mixed my gain with the throttle so it will drop the gain value as the throttle increases.
        I thought about that but decided against as sometimes I am flying fast at low throttle (steep dive). I couple gain to gear, since I'm never flying fast with the gear down.
          Yeah, if anything, you want to adjust gain based on speed, not throttle. Which either requires IAS telemetry or manual switch throws.
            Good points. I still have gain on a knob to adjust as needed. I wonder if you can mix it with a gps telemetry or actual airspeed sensor...
              Depends a bit on which radio system you use I guess. There are some that certainly can, and some that can not.
              • Ordered a TV unit from RCcastle dec 17. Came in 0n jan 19 packaged very well and undamaged. The only minor disappointment is that the decals applied to the stock exhaust are not on the TV unit. I know that would add to the cost so I'm happy enough. Hope to have it installed and in the air soon. I wanted to buy from Motion but with no idea of how many units coming in and no pre order i was worried i wouldn't get one this round.
                • 90mm Click image for larger version
                  • You installed a 90mm fan? Have you flown it yet?
                    • I'd love to shove a 90mm in the Gripen.
                      Kudos if you can actually make it fit and perform well.
                      It seemed like way too much carving and too small an exhaust to me, plus would need more air to feed it.
                      • Has anyone had any issues with the Gripen main gear doors not closing completely? The gear appear to be straight and the I adjusted the ball links. However, the doors do not want to seem to want to close completely in the front any more.
                        Thanks,
                        Tone
                        • I have the same issue. Check to make sure the grub screws holding your landing gear are tight. One of mine were loose and the right gear was getting caught on the door when the gear came up. They still sometimes fail to close completely if I’m at full throttle when I bring up the gear but it reduced the incidence of it occurring.
                          Originally posted by TS8103 View Post
                          Has anyone had any issues with the Gripen main geer doors not closing completely? The gear appear to be straight and the I adjusted the ball links. However, the doors do not want to seem to want to close completely any more.
                          Thanks,
                          Tone
                          • Copy-paste from RCG:
                            I adressed this early in the thread.
                            In addition to what has been commented already (pins coming loose and causing the struts to pivot), the strut design is weak where the wire that interacts with the door closing mechanism attaches to the strut, as Freewing made 4 holes there, reducing the cross-sectional area and causing the strut to bend there on hard landings. Oftentimes it is not very visible at first glance but you may notice your struts are bent at that particular section on close inspection. If that is so, take them out, bend them back straight and 'maybe' you get the doors to close again.
                            I say maybe because first time this happened I managed to solve it this way but the second time I only reduced the problem, not totally resolve it. Wish Motion/Freewing provided better struts.
                              There's ALWAYS something!
                              They should get us as their beta testers.
                              • The strut looks straight but you may be on to something. It would account for why adjusting the ball link on the door itself has. It resolved the problem. When I get home, I will put a straight edge on it and see what it looks like.
                                Thanks,
                                Tone
                                  Amen!
                                  BTW, Jetfan upgrade is done... now waiting for a calm afternoon to remaiden.
                                  CG is now 23-24mm aft of stock marks (finally!).
                                  • I like your storage racks.
                                    • For all the people griping about delays in delivery:
                                      SINGAPORE — A critical shortage of containers is driving up shipping costs and delays for goods purchased from China.
                                      The pandemic and uneven global economic recovery has led to this problem cropping up in Asia, although other parts of the world have also been hit. Industry watchers said desperate companies wait weeks for containers and pay premium rates to get them, causing shipping costs to skyrocket.
                                      This affects everyone who needs to ship goods from China, but particularly e-commerce companies and consumers, who may bear the brunt of higher costs.
                                      https://www.cnbc.com/2021/01/22/ship...s-to-rise.html
                                      • Does the full size Gripen have thrust vectoring or is it just extra for the model?
                                        • Originally posted by Captain Moron View Post
                                          The full size has no TV. It's an addition to the model.
