T-33 Retracts Issues
  • T-33 Retracts Issues
    Hi Folks,
    I am having problems with the retracts on my T-33 and I am at a loss as to what to do. I hope someone in this group can give me some advise .
    I bought this T-33 airplane back in Feb 2020. It took me a month or so to put it in the air and, given that I just came back to the hobby after a 12 year hiatus, I have not flown it much until I rebuild my skill (maybe 10 times so far). From day ONE, the retracts misbehaved. After I realized that there was a delay in deploying and retracting (likely by design, programmed from the factory and part of the set up of "Blue Box" where the servo get plugged) the main gear would deploy and retract fine but the nose gear would not reliably deploy. After a while I realized that if I cycled the process twice, it will deploy (i.e., flip the switch, wait for the main gear to deploy, then retract it, then flip the switch again and NOW all main AND nose gear would deploy). Unfortunately, I did not complain to Motion RC (as I found a "workaround") at the time so my warranty ran out. Well, the "workaround" stopped working last week and I had to land without the nose gear (saved the plane but scratched the belly).
    I then proceeded to bypass the "Blue Box" (using a three pronged Y harness and going straight to the receiver) and ...
    a) With just the nose gear going directly to the Rx (and the main to the Blue Box)... the nose gear would work well... until it did not and operation became unreliable as before.
    b) With nose AND main gear going directly to the Rx... they worked well... until they did not and all THREE became unreliable
    c) Then I went back to "a" and this works fine about 80% of the time (i.e deploys 80% of the time at the first or second attempt)
    At this point, I do not know what the problem is or what else to do. Now I only dare to fly it with the landing gear deployed... but that is a shame as it takes some of the fun away.
    Has anyone experienced a problem like this with the T33 or any other Freewing retracts? - Does anybody have any idea of what the problem can be or how to go about solving it?
    I would appreciate any input that you can offer.
    Thanks,
    Cesar.
    San Diego, California
    Hi Cesar, the first thing to check is if the wheels or struts are having any contact to the wheel wells whilst retracted. This can happen after a couple of landings with even slightly bent struts. Did you remove the retracts from the plane to see if you get 100% reliability then?
    The electronics inside the extracts are very sensitive, once the motor pulls too much current it is stopped.
    Frank
      I will check that out tonight and report back. Thank you Frank.
        Hi
        If you search in this forum you could find info about this.
        https://www.hobbysquawk.com/forum/rc...755#post262755
        https://www.hobbysquawk.com/forum/rc...807#post261807
        its all being mentioned before....
        regards Hans
          I find that the first time i drop the gear the nose gear does not go down. I transport the plane with gear up so i drop them then retract them drop them again and nose gear works and has not failed in the air.
          i have a freewing rebel and nose gear sticks up now and then. When it happens i move the rudder stick back and forth and drop gear and it seems to unstick and go down.
            Some retracts on some planes need to be "cycled" at least once after the battery has been installed. That's just the nature of them or it's because the gear goes through a control box that has a sequencer built in. Even without sequenced gear doors, they still may need to be cycled.
