F7F-3 Tigercat
HSD ME-262 ESC beeps
  • HSD ME-262 ESC beeps
    Hey guys,
    I'm having trouble deciphering all of these beeps from the ESC for the HSD ME-262. I've tried reversing the throttle like most people suggest with a Spektrum radio (I have the iX20 and I'm using an AR8360 receiver), but when I do that, all I get is a series of non-stop fast beeping (even after re-binding with the reversed throttle). So, I'm out of ideas and there's not a lot of information out there on this. Does anyone have any suggestions?
    Thanks.
    Never mind - If you ever have a situation using a Spektrum radio with HSD ESC’s here’s the solution:
    1. Turn the transmitter on, set the throttle to highest position (i.e. full power)
    2. Connect the batteries
    3. Wait until the esc’s beep and then go to lowest power setting on throttle *** CAUTION *** HOLD ON TO THE MODEL! The engines will come on line at full power and believe me, these engines make a LOT of thrust. Make sure you’re not around anything that can be sucked down the intakes.
    4. Reverse throttle setting.
    5. Re-bind.
