Originally posted by Splat
View Post
Originally posted by Gringotuerto View Post
Wow, congratulations. You are fearless, jumping back in with a large EDF jet. Glad it went well!
Much thanks to everyone here for the help, I think each flight will get better and better now that I can tweak little things here and there. Still have to play with the CG and the elevator trim and expo to get her dialed in and shorten that take off run lol. I have those 12 bladed fans sitting on the shelf too that might call for a upgrade to inrunners down the road. Loving this bird.
Originally posted by crxmanpat View PostI say stick with the 9-blades, the 12-blades are less efficient. If you really want an upgrade, get a pair of the T-33 fans/motors. These are inrunner 9-blades and will give you more grunt on takeoff.
Originally posted by Splat View Post
Isn't the T-33 9 blade fan the same as the fan that is in the A-10 right now? I could just buy two of the 3658-1920kV Inrunner'sand swap the motors out yeah?
I figured it's like riding a bike right? lol Not going to lie, my heart rate was certainly high but the rush after completing those two flights was well worth it!
Originally posted by evensen007 View Post
Probably going to maiden mine today on the HRB 6000's (810grams), and wondered where you CG'd that made it feel too nose heavy leading to a long take off. Should I not go by book CG on the maiden, or is the general consensus to move it back a bit?Pat
Originally posted by crxmanpat View PostThe consensus is that the book CG 78mm is too nose heavy. It will fly fine there, but you really have to be on top of your landings to keep the nose up. Most of us have moved the CG back to 85-90mm. I've found 86mm to be the sweet spot.
Originally posted by crxmanpat View PostI've found 86mm to be the sweet spot.
Generally speaking I've found the instructions from MotionRC to be : (a) overly cautious on CG; (b) overly crazy on aileron throw. I start with aileron throws at 50% of the manual and work up from there. I start CG at the manual-specified point (unless I've got solid info that it is safe to go aft) and work back from there.
Yeah the aileron throws are pretty crazy which brings me to a question...
So I dialed in -30% expo on all control surfaces on my Futaba T6K radio after I saw a video online somewhere...is negative expo what I want to be doing or is it positive 30%?
Also getting back to those T33 fans/motors...do they just drop into the A-10 nacelles pretty easily. I mean I assume they are the same fit as the stock 80mm fans in her now?
Originally posted by Splat View PostYeah the aileron throws are pretty crazy which brings me to a question...
Given that I'm still a bit green, I'm trying to keep things as simple as possible by having my aileron and elevator dual rate linked on the same switch. I'm running an ix12. I hear you that the ail throws are insane. I've measured them and set them per the manual, so I was thinking of setting my base/standard setting for ail/ele to 60/90. I'm going on the assumption here that this big bird needs all the elevator throws you can give it. Then my higher rate will be 75/100 for the second switch position. I will take-off, trim, and land in the base 60/90 throws to start with. Does this seem solid/reasonable? Did you need to mix in any elevator with the flaps deployed at either half or full?
Would also appreciate if someone with the HRB 6000 batteries could post a picture showing how you have your batteries set. I can't really get the canopy closed no matter what I try. Did you carve foam?
Originally posted by evensen007 View PostGiven that I'm still a bit green, I'm trying to keep things as simple as possible by having my aileron and elevator dual rate linked on the same switch. I'm running an ix12. I hear you that the ail throws are insane. I've measured them and set them per the manual, so I was thinking of setting my base/standard setting for ail/ele to 60/90. I'm going on the assumption here that this big bird needs all the elevator throws you can give it. Then my higher rate will be 75/100 for the second switch position. I will take-off, trim, and land in the base 60/90 throws to start with. Does this seem solid/reasonable? Did you need to mix in any elevator with the flaps deployed at either half or full?
I can't say about the HRB 6000. If it's anything like my 5000mah Turnigy Heavy Duty or ChinaHobby Line or Revolectrix (all about the same size), I cannot close the canopy. I would have to auger out quite a bit of foam in order to close it. Hence, I don't use those batteries in favour of the much smaller Gens Ace 5000's and the first gen of Admiral 5000's. The new gen of Admiral come in a much different shape so I can't say if they'll go in and allow the canopy to close.
Originally posted by xviper View PostI have the opposite experience than you regarding the rates on the AIL and ELE. On my A-10, I find I need much higher throws on the AIL to make it roll easily due it being such a big, heavy plane. I also find that the ELE is very sensitive, especially during landing that I need to use a very low throw or it becomes a roller coaster ride coming in. However, I do need a higher ELE throw to rotate on take off.
Oh, great. I had bought them based on some people in this thread recommending them. hah. Hope someone else chimes in that has 2 large batteries in there. Someone was talking about using 8000's, so there's gotta be a way! In regard to the ail/ele, that was directed at the poster above that said the ailerons were insanely touchy. Now I'm not really sure how to set the rates. I might just leave them at 100 and chop them to 65% for the lower rates.
Originally posted by xviper View PostThose 8000's are the "HobbyStars" purchased off Amazon. They are exceptionally small in dimension and weight for their claimed mah. If you go to each of those batteries' webpage, you will see the dimensions for them. The HD dimensions are 146 x 51 x 57mm (51mm being the limiting height).Those 6000 HRBs are 155x48x54mm (48mm being the limiting height). I know for a fact that the HD will not allow the canopy to close if placed on the front battery tray (over the nose retract). Since there's only a 3mm difference (and 50g difference), I can see that the HRB won't allow the canopy to close either. Now, if somehow you can place the front battery on the main floor (lower) and get the rear battery far enough to the rear, you may be able to balance, but I think that may be a trick. I've tried that with the smaller Gen Ace 5000's, with the control box unscrewed and moved way back to the rear wall and the plane is still quite tail heavy. It just seems to need one battery on the front upper tray to balance. You may have better luck than me. Of course, you can carve out a bit of foam and still have a solid canopy.
