Yup with those 6000's you are going to need to move that board to the back two screws...had to do it to even get anywhere close to a balanced CG with my Admiral 6000s and still think they can go back further to get that 86mm mark.
Originally posted by Splat View PostYup with those 6000's you are going to need to move that board to the back two screws...had to do it to even get anywhere close to a balanced CG with my Admiral 6000s and still think they can go back further to get that 86mm mark.
Originally posted by evensen007 View Post
Alright, you guys are good! Moved the board back onto two screws. Moved the batteries all the way back, but it still seems nose heavy off the 85-86mm mark. Can you post a pic of your plane and where on the wings you are marking 86mm?
I fly the 8000 mah, and my CG is 92mm for windy days, and 95mm on calmer days. Move the blue board back like previously mentioned, then extend the battery straps, put some non skid between the two packs, then strap them together and then into to the bird. My 8000's give me 4.5 to 6 minutes of flight time depending on my throttle usage.
Good to hear from you! Back home!! Ok,, now I'm wondering if buying these: https://www.motionrc.com/collections...inrunner-motor, was a mistake after some people say 9 blade is better. Which is it? Thanks in advance.
Originally posted by Warthog View PostGood to hear from you! Back home!! Ok,, now I'm wondering if buying these: https://www.motionrc.com/collections...inrunner-motor, was a mistake after some people say 9 blade is better. Which is it? Thanks in advance.
People here love that power system, they've put it in everything from their underpowered, overweight F-16's to their F-4's and F-15's. At the time I was looking at re-powering my F-16, these were out of stock, just like they are now. So I went with the 90mm FMS power system. It was lighter, more efficient and with the weight savings only lacking about 300 grams of power to weight ratio over this system. As a bonus it's 68 bucks cheaper, so I bought 2 and put one in my F-4 as well.
I've always flown my A-10 on the stock 80mm 9 bladed power system and even with an flying AUW of 17 lbs have never felt like it was lacking in power or vertical. I think the stock power system is easily twice the power of scale flight in this bird, and I love the scale like whine that the 9 bladed system gives her. I bought her with the thought process that I'd purchase the 90mm nacelles later, and never did, completely happy with her 80mm power.
Originally posted by Demetrius View PostHere's her in flight!I solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
Originally posted by Gringotuerto View Post
Has the A-10 always had the same stock motor and fan? I ordered from the first batch, and am not sure if it has the same power system that it ships with currently.Pat
Thanks to Splat for correcting me via PM's (and really all of you in this thread) I think I have my CG good. I would say it's closer to 90mm than 86mm at this point but I think that's ok. I am using the HRB 6000's which are about 810 grams in the staggered setup pushed back as far as they can go. The battery strap is pretty much near the last inch of each battery. The cockpit does fit, but bows up just a tiny bit so I'm going to carve a touch of foam. Maiden tonight; wish me luck!
Originally posted by evensen007 View PostThanks to Splat for correcting me via PM's (and really all of you in this thread) I think I have my CG good. I would say it's closer to 90mm than 86mm at this point but I think that's ok. I am using the HRB 6000's which are about 810 grams in the staggered setup pushed back as far as they can go. The battery strap is pretty much near the last inch of each battery. The cockpit does fit, but bows up just a tiny bit so I'm going to carve a touch of foam. Maiden tonight; wish me luck!
Originally posted by evensen007 View PostThe battery strap is pretty much near the last inch of each battery.
These are RoaringTop 5800's. Canopy fits just fine with them in. The RT's are slightly slimmer and longer than most other similar size packs. I'll even toss 6250's in there occasionally and they fit fine too.
I have Admiral 6000's I want to try out in her. I wonder what my placement will look like? Anyone flying her with Admiral 6000s?My YouTube RC videos:
Originally posted by Aros View PostI have Admiral 6000's I want to try out in her. I wonder what my placement will look like? Anyone flying her with Admiral 6000s?
