This is my F-16N rendition. Did a number of mods to the plane and they're detailed in F-16 Mod thread in RCG.
Official Freewing 70mm F-16C Falcon V2 Thread
swapped out my fan today. took a closer look at the stock one and was pretty disappointed. The fan looked horrible!!! really bad molding and the quality was just bad. It had started to make funny sounds and I see why now.. The housing was the same as a Cyclone 70mm that I had left over so I put the xrp 14 blade and Dr. Madthrust 2200kv inrunner in there. Dropped right in after I did some balancing. Will test it out tomorrow. With a near dead battery the plane had more power than the 12 blade did with a fully charged pack. Test flight tomorrow....Check me out on youtube at https://www.youtube.com/user/gooniac33
Originally posted by gooniac33 View Postswapped out my fan today. took a closer look at the stock one and was pretty disappointed. The fan looked horrible!!! really bad molding and the quality was just bad. It had started to make funny sounds and I see why now.. The housing was the same as a Cyclone 70mm that I had left over so I put the xrp 14 blade and Dr. Madthrust 2200kv inrunner in there. Dropped right in after I did some balancing. Will test it out tomorrow. With a near dead battery the plane had more power than the 12 blade did with a fully charged pack. Test flight tomorrow....
It should be lighter and hopefully more powerful... Not to mention glass smooth with better sound!
gooniac33, nice flights but I have to tell you I might chop off a foot to have that million mile runway and open terrain to fly at. :Drooling:My YouTube RC videos:
Originally posted by urrl View PostGooniac is the F-16 easier to tip on landing than the 70mm F-104 or are they about the same?Check me out on youtube at https://www.youtube.com/user/gooniac33
Originally posted by gooniac33 View PostI swapped out the fan and am happy with the results!! XRP 14 blade rotor in a Cyclone housing which is the same dimensions as the stock Freewing fan. Take a look
Originally posted by Laserdude View Post
Nice flights and it appears the new power setup is preforming nicely. Looks like you are getting 3.5 to 4 minute flight time. What size battery are you running?Check me out on youtube at https://www.youtube.com/user/gooniac33
Originally posted by tezact View PostHET/Wemo vs Freewing Pro
Hi folks,
I have just done some tests for the Freewing Pro setup vs. a HET 1W40 powering a 70mm wemo Pro fan in an all alloy Extreme RC housing.
NOTE: the Extreme alloy housing did NOT have an inlet lip so you should add 15% to its thrust figs.
The tests were done on my test jig and not mounted in the airframe.
The same Hobbywing Platinum Pro 100amp ESC was used and the same 6S 60C battery was topped up between runs
HET/1W40 3300kv
Peak amps 99
Peak watts 2217
Ah 0.135
Wh 3.0
Thrust 1800gms +15%= 2070gms to allow for no inlet lip
Freewing Pro setup 2300kv
Peak amps 75
Peak watts 1742
Ah 0.107
Wh 2.4
Thrust 2160 gms
Conclusion: Freewing have done a great job matching the fan/mtr. The HET Wemo setup is pretty close for thrust but certainly an "amp hog" compared to Freewing
So its stay with the Freewing setup for me.
Tezact
Not too shabby for a 70mm setup
Nice information, texact, thanks for posting. I have found the SkyRC GPS logger to be accurate to within 2mph, which is impressive for its form factor, feature set, and price. It's a neat device and while it's on the slightly large size, it records a range of data from speed to altitude, etc. I keep forgetting how to set it, though, so if you get one, keep the instruction manual handy! I get about five hours of recording time, which is lots of data when evaluating prototype aircraft here at Motion RC Skunkworks ;)
I take it this is the device you're talking about?
SkyRC GPS Speed Meter - SK-500024 Do you find yourself wondering how fast or how high your RC aircraft can fly? Wonder no longer with SkyRC's GPS Speed Meter. The popularity of GPS devices inspired SkyRC to design this handy telemetry-driven gadget that comes in around 40g. The Speed Meter is the result of SkyRC’s ongoLive Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
I have the 4S Falcon and it's my first edf ever. In fact I'm not putting it together so I won't be tempted trying to fly it! I've been reading here about this 70mm and more so the 90mm regarding getting the CG right and difficult handling, hard to land. I'm also hearing them getting praise, once you figured the CG!
Here is my evaluation having only taxied it across the living room floor, unglued vertical bobbling. Let me know if I'm all wet. :Silly:
Beautifully designed and so light, with a 3700mah. The technology blows my mind. My only experience with a foam r/c was my Midwest Attacker with a OS 45 FSR. The youngsters can google that. Very primitive by today's offerings! But it flew great!
Bad handling F-16? I blame the wing wash out, or lack there of. That's one of the characteristics that has always stood out to me on the F-16 and F-15 and most modern jets, a lot of wash out.
Mine has little. I've not put my incidence meter on it (I've not found where I put it years ago :Confused:) and I know it's a small wing, but I think on the full size Viper the wing tip missile has a definite nose-down attitude, but on mine they look parallel to the fuselage centerline. The wing twist is also very obvious when you see that contrail that forms off the wing tips, gives me chills!
So is it possible to add washout to epo wings?
Just the other day I watched my buddy take the end of his warped B-17 wing tip and apply a hand held heat gun to it, reshaped it and let it cool so it was flat again. I suspect the opposite could be achieved just as easily. Apply a towel to the foam before applying heat to reduce the chance of bubbling the cells. Good luck!My YouTube RC videos:
Hi Boots, Adding washout to the wing itself *could* be done, but having designed this aircraft, I would personally recommend that you don't. If you're after the visual appeal of the downward angled pylons, I would recommend removing and regluing the pylons at the scale angle of incidence. This would achieve the visual scale effect on the ground and when flying by to a lesser degree. With a plane this small, and moving this quickly, your eye won't perceive the "twist" in the wing itself (partly because the thickness of the foam trailing edge is greater than the total twist's change over the wingspan's distance) and you'd be changing how the model was already designed to fly. Which, by many accounts, is really nicely. 'Not that I"m biased. Ha! :D
