Freewing T-45 Goshawk 90mm EDF Jet PNP
Flat Foam Tires?
  • Flat Foam Tires?
    Hey guys, if you leave your plane sitting on the foam tires for a while, you will get a flat spot. (that why we usually use stands)
    I had this happen with my FW F4 Phantom.
    Does anyone have any ideas for how to return the foam tire to its normal shape? Nothing I have tried has helped.
    Marc flies: FW & FL MiG-29, F4, A4, A10, F104, P38, Dauntless SBD, Corsair, both Tigercats, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen. AL37, FOX Glider & Radian XL.
    No idea, but I use foam under the wheels when storing and no flat spots.
      I saw a video showing a guy getting dents out of EPO using hot water. He said around 150-160F but do not boil. Maybe you could try that ???He heats it up and works the shape back
