Official Dynam Seawind 1220mm Thread
  • Official Dynam Seawind 1220mm Thread
    (Click here for the PNP product page and here for the RTF product page).
    The Dynam Seawind is a fun, go play-for-the-day amphibious, snow and land aircraft. Enjoy some fun flying on your favorite lake, pond or river. Snowing outside? No problem! Want to fly off the tarmac? Easy! With the included landing gear, you can fly the Seawind on land with ease. Simply remove the gear to fly off of water or snow. Just add your radio, receiver and 3S 2200 LiPo battery and you're ready for adventure.
    FEATURES:
    • Unique, attractive lines and decal trim sheet
    • Two scale pilots for added detail
    • Powerful BM3715A-KV1050 Brushless Outrunner motor
    • Landing gear set for flying off of land if desired
    • Constructed of Durable EPO foam
    INCLUDES:
    • Dynam Seawind Blue 1220mm (48") Wingspan - Receiver Ready - (PNP)
    • ESC with XT60 connector, servos and motor come pre-installed for your convenience
    • Blue Decal set
    REQUIRES:
    • 4 Channel Radio - Select a minimum 4 channel radio from our Radio Collection
    • 4 Channel Receiver - Select a minimum 4 channel receiver from our Receiver Collection
    • 3 Cell 11.1V 2200 mAh LiPo Battery with XT60 connector - EPR22003X6
    • 3 Cell Compatible Battery Charger - Select a minimum 3 cell (3S) charger from our Charger Collection
    Click image for larger version  Name:	dynam-seawind-blue-1220mm-48-wingspan-pnp-motion-rc-26213556876_1024x1024.jpg Views:	0 Size:	130.4 KB ID:	196847
    having trouble...cant make heads or tails of this...thought i had it...began taxiing out like your video and the cockpit filled with water!
    after emergency cleanup, this is what happens and I do not have the experience to problem solve and identify the issue.
    Please see files and email me with any help. thank you. Click image for larger version
ID:	211968Click image for larger version
ID:	211969Click image for larger version
    it just goes beep-beep........beep-beep....over and over.
      These "water planes" are not waterproof out of the box. They must be completely sealed and all electronics wrapped and sealed from water intrusion. The "beep, beep" is probable indicating that the ESC is not initializing, perhaps meaning that it's not talking to the receiver. The electronics may now be water damaged. Try re-binding after you dry everything in a bucket of dry rice for a day. Also do a check of the battery with a tester. Water, especially salt water, will kill a LiPo battery. Even fresh water will contain enough salt and minerals to drain a battery to death.
        Its binded. tried to do video but no.
        i can switch modes and all that...the colors on esc changes 2 times, 3 colors...ive tried a diff battery and all.
        checked beep patterns and best i can see it relates to voltage but, ive tried several batteries.
        will try video again.
        Ive read everything but cant figure out why...
          Water damaged electronics may never work again. Are you sure it's the ESC that changes color? I don't think any of my ESCs have any lights on them.
