FlightLineRC P-38L Lightning Allied Green
Strega CG
  • Strega CG
    unless I modify the canopy, I don't think I can set CG at 93mm wing root at fuse. this is with an Admiral 4S 2200 no less. still nose heavy. Any one else have issues?
    Re: Strega CG
    We have not had any issues. Do double check your CG machine. Mine was making everything 10mm off and very tail heavy. I, like you, had to add a load of tail weight to planes and it turned out my CG machine was off. I borrowed another CG machine after I verified my "finger tip balancing" did not agree with my CG machine. This verified my CG machine was off. Hopefully that is it because it would be a simple fix.
      Re: Strega CG
