Thanks xviper!
Avios/Hobby King 1600mm C-130 Hercules
Originally posted by xviper View Post
I'm wanting to buy this plane and I'm interested in longer flight times. Can anyone recommend a bigger sized 4S lipo (higher mAh rating) that is a good match for this plane?
And how long of flight times would you say you're getting with the batteries you're using now? Any links for those batteries?
Thanks!
I haven't flown mine yet, but I'm using the Turnigy Graphene 2.2 mah, 4s battery. It's one of the heaviest batteries in the 2.2 size. It's more equivalent to a 2.5 to 2.7 mah. The plane is already a bit on the nose heavy side with the Graphene in it. Any heavier battery will make it very nose heavy. Ideally, a more normal sized 2.2 like the Admiral would balance this plane better. If you really want to use a bigger battery, you will have to do a little excavation of foam and relocate the battery tray further aft or add weight to the tail. As is, people have reported earlier in this thread that they can fly for 8 minutes (post # 305). That's quite good for most electric planes, especially one with 4 engines.
I don't have links handy but HobbyKing sells the Graphene and other series of batteries and Motion RC sells the Admirals. 2.2mah, 4s is fairly common.
Originally posted by xviper View PostI haven't flown mine yet, but I'm using the Turnigy Graphene 2.2 mah, 4s battery. It's one of the heaviest batteries in the 2.2 size. It's more equivalent to a 2.5 to 2.7 mah. The plane is already a bit on the nose heavy side with the Graphene in it. Any heavier battery will make it very nose heavy. Ideally, a more normal sized 2.2 like the Admiral would balance this plane better. If you really want to use a bigger battery, you will have to do a little excavation of foam and relocate the battery tray further aft or add weight to the tail. As is, people have reported earlier in this thread that they can fly for 8 minutes (post # 305). That's quite good for most electric planes, especially one with 4 engines.
Thanks!
Originally posted by Nickerz View Post
Good to know! I agree, 8 minute flight time would be good enough for me! So 8 minutes on a 2200mAh? Nice! And I'd be flying it scale so I'm sure I could get that or maybe even better with good throttle mgt...
Thanks!
I got one and then had to send it back. I had it all set up and was fine tuning the flaps when the electronics went poof! HK took it back without any squabbling and refunded my money. The foam body is BEAUTIFUL! 9 gram plastic geared servos all the way around seems weak. I was going to swap all the servos out until the poof event. Hey MRC, make a great C-130 with quality, the market is asking for it. By the time I upgrade electronics with time and materials I have spent another $100-$125. Sure was sad to send it back...
- Likes 3
Finally got a chance to maiden mine. Grass had just been mowed quite short. Take off was easy - no flaps. Landing was text book- no flaps, looked just like a real C-130. Grass didn't pose any problems. However, it was very gusty and turning on the ground was difficult as it weather vaned and tipped onto one wingtip but it will eventually turn. This plane is from the latest batch (V2?) and everything on it worked perfectly. It looks beautiful in the air. Using a 2200mah, 4s Graphene battery, I got 5 minutes but each cell went down to 3.75. I'll reduce time to 4:30 from now on. For once, I'd say this plane is NOT underpowered. I would consider this model to be MAGNIFICENT!
Here's a video I tried to get with my hat cam. Unfortunately, it cut out part way through the flight, but you get to see it roll on the grass and take off and do almost 2 circuits.
Originally posted by wvrailfan View Post
The first couple of videos from private owners didn't look promising. I'm happy to discover that my C-130 flies astonishing well - nothing like the roller coaster rides and wing stalls from those early vids. Credit where credit is due. Great value, thumbs up to HobbyKing.
Originally posted by xviper View PostLove that camera position. Got my decals from Callie also. One day, I might get the Fat Albert. Must thin the heard down a bit first.
