E-Flite P-47 Razorback 1.2m (48")
Originally posted by uuc328 View PostIs this the official thread on the plane? Failed to locate anything other than FS threads while searching, maybe I'm doing something wrong.
It is indeed a great flying airplane. I prefer Eflite's Corsair in the same size, but the Razorback doesn't disappoint, either. Its wide gear stance is especially helpful in sticky landing and taxiing situations.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Originally posted by Alpha.MotionRC View PostIt is indeed a great flying airplane. I prefer Eflite's Corsair in the same size, but the Razorback doesn't disappoint, either. Its wide gear stance is especially helpful in sticky landing and taxiing situations.
Originally posted by boomer108 View PostDoes anyone know what color blue the cowling is on the plane? I need to do some touch up and I can't get a color match from Home Depot because there is no flat surface.
This is not the exact match but pretty close. I also had trouble locating the right color.
Hope this helps
Another thing too, you can try a hardware store like Home Depot or Lows and ask for sample paint. They can also mix and match for you. That's what i did for my SU35. Got a perfect match from Home Depot. The down side is that you will have to apply it with a brush unless you have air compressor and a spray gun that will accept latex paint.
Can't stand the livery on the eflite F4U, so much that it pushed me to the dynam then some pricy upgrades. If you guys ever offer a different scheme...
In my humble opinion, I cannot recommend Dynam. They are cheaper, yes, but the quality, finish and flight characteristics have no comparison to other brands like Flightline, FMS and E-Flite.
*P.S. I forgot to mention graphics are from Callie Graphics, of course. She does great work, and typically my planes are maybe $25 - $35 per livery.
Originally posted by Sam CS View PostHi Guys,
Just want to share my setup for Razorback from E-Flite.
I love this plane in FPV and LOS
YouTube link (was out flying, looking for fireworks this summer on the 4th of July)
Here is my setup:
Airframe
- MDL: P-47 Razorback 1.2m/48" (E-Flite)
- ESC: ZTW Gecko 65A ESC with 8A SBEC
- BAT: 4S Admiral Pro 5000mAh
- FC: Eagletree Vector, GPS, PSU
- HDT: Fat Shark 9g 180* Pan Head Tracking Servo
- Canopy: Custom build (Balsa & 1/8 Hobby Plywood, Plexiglass: Bayer)
RC
- TX: FrSky X9D+ with 900MHz Long Range Module
- RX: FrSky 900MHz R9
FPV 3.3GHz
- CAM: RunCam Split 2
- VTX: Finch 3.3-3.4GHz Racing Transmitter 50/200mW Coax V2
- ANT: 3.3/3.4GHz BlueBeam ULTRA Antenna Set (RHCP) - VAS IBCRAZY
Ground station
- Eagletree Eagle Eyes diversity box
- VRX: Two R3300V2 3.3 GHz 16 Channels Pocket-Size Receivers
- ANT1: 3.3/3.4GHz BlueBeam ULTRA Antenna Set (RHCP) - VAS IBCRAZY
- ANT2: TrueRC 3.3/3.4GHz X2-Air 13dBic Directional Antenna (RHCP)
- RPTR: FatShark 5.8ghz Repeater (Ant: Standard clover)
- GGLS: FatShark Dominator V3 FPV Goggles
- Goggles VRX: 5.8 GHz Furious True-D Diversity Receiver V1
- Goggles ANT: Standard clover
- Goggles HDT: FatShark Trinity Head Tracking module
Originally posted by wallacems View Post
So is the only thing you changed to go 4 cell the ESC? Is the motor still stock? I know stock has a 40AMP ESC and I saw another post on how it overheats and goes into overtemp shutdown on a 4S. I have a couple 4S 3000mah batteries I want to use for it. So it would be cheaper to change the ESC. Thanks.
