Two left feet? Like me on the dance floor! LOL
Originally posted by t01ga View PostI haven’t maiden this bird yet cause I can’t stop adding details. It is the queen of my hangar.I solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
Wow, love it!!
What are you using for the raised rivets on the canopy? Just fantastic!
Originally posted by Aros.MotionRC View PostWow, love it!!
What are you using for the raised rivets on the canopy? Just fantastic!Tolga
Instagram: @_t01ga_
YouTube: t01ga
Thanks LB. I envy you pilots who have been flying her so far.I solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
Originally posted by Elbee View Post
T, you are further along than I, sir. Mine is NIB downstairs, though waiting patiently. Best, LBTolga
Instagram: @_t01ga_
YouTube: t01ga
- Likes 2
Mine stayed in box for two months whilst I was finishing off the winter project. What is holding you up LB?
Originally posted by sethscorsair View PostWhat is the best way to add rudder authority i need a little more on landing and taxi.
Originally posted by xviper View PostIncrease servo travel on the rudder channel. With Spektrum, you can go as high as 150%. Keep the high rate on rudder at 100%, 0 expo. Also, give it full UP elevator (on high rate) to plant the tail wheel while taxiing.
T01ga,
Great job! You got pure talent!
I had a brown out on mine today, sadly. 3rd touch and go. Got attluide and make a turn running parrallel to the runway. Started a barrel roll and right when started to come down, lost control and down she went.Planes
I had a brown out on mine today, sadly. 3rd touch and go. Got attluide and make a turn running parrallel to the runway. Started a barrel roll and right when started to come down, lost control and down she went.Tolga
Instagram: @_t01ga_
YouTube: t01ga
Sorry to hear that man. I hope it is fixable. Thanks for the complimentPlanes
Not sure. No cause to why it happen battery was 3,94. Running admiral battery, admiral rx.Planes
To increase to 150 in the reciever?
You can go to a longer servo arm and use a hole further from the center of rotation, making the servo move the push-rod more per degree of rotation.
Anything beyond 40 deg of rudder deflection is not as effective for increasing steering (per degree) turn as for increasing drag. So if you are already getting that much rudder you may not gain much from increasing the rudder deflection.
Adding rudder area of course helps, but that isn't practical here, since it would mess up the scale appearance.
Since you'll usually have more issues trying to turn right than left, you could try shimming the motor mount to have a little more right-thrust.
If its from trying to taxi in a crosswind, you might just have to pick up the airplane. there is some maximum crosswind where you just can't keep the wind from turning the airplane to turn into the wind.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
PS. I maidened mine today and with servo travel at 100% and high rudder rate at 100% and full UP, ground handling was more than adequate. This plane is very light on its tail as compared to my much heavier FMS 1700mm Corsair, so it does require UP on the elevator or the tail wheel won't track well.
