View Post
I solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
- Likes 2
Originally posted by dmyers0403 View PostDid Maiden on mine yesterday. Much better flyer than my original V1FMS 1700 I still have. I will admit to liking the larger size of the FMS but not the least bit disappointed in my FW.
The FW Corsair has power to spare. Took off at half throttle in about 50 ft. no flaps into good 10 plus headwind. Very solid flyer with almost no trim required. Did not bounce around in wind just very groovy at half throttle with comfortable speed. Pulls pretty large loops with added power. Never needed full power with level flying. Set up for landing with no flaps because of good steady 10 plus headwind. Just a beautiful decent holding a little power (not a glider). Easy flare for grease a wheel landing. Flew about 4 1/2 minuets with 4.07 volts per cell left on 6S-6000 mah Battery so will have plenty for longer flights. Will reset timer to 7 minuets for next flight.
All controls per Hi spec using 30% expo. Love it.
Got 5 flights in today on my Corsair, running 8 minutes on a 5000. Plenty of power, smooth landings, just a real pleasure to fly. Same with the FL Spitfire, but with that I'm getting almost 10 minutes on a 5000. These are 2 of my favorite prop warbirds and FL did an outstanding job with them. Also got 5 flights on the FMS 1700mm P-51. I like the size and it looks good in the air, but it is still a dog compared to the Corsair and Spitfire. I have to use a 4000 because any heavier battery really degrades the performance. Although it has the 360 Kv motor, the aircraft is just way too heavy and I suppose going to an 8S setup would help, like with the FMS Corsair, but I'd rather spend my time and money on another FL/FW model. It still flies OK with the 4000, climbs decently and gives just under 5 minutes.
- Likes 3
Originally posted by Hugh Wiedman View PostGot 5 flights in today on my Corsair, running 8 minutes on a 5000. Plenty of power, smooth landings, just a real pleasure to fly. Same with the FL Spitfire, but with that I'm getting almost 10 minutes on a 5000. These are 2 of my favorite prop warbirds and FL did an outstanding job with them. Also got 5 flights on the FMS 1700mm P-51. I like the size and it looks good in the air, but it is still a dog compared to the Corsair and Spitfire. I have to use a 4000 because any heavier battery really degrades the performance. Although it has the 360 Kv motor, the aircraft is just way too heavy and I suppose going to an 8S setup would help, like with the FMS Corsair, but I'd rather spend my time and money on another FL/FW model. It still flies OK with the 4000, climbs decently and gives just under 5 minutes.
Originally posted by xviper View PostJust checking ................... The stock FW Corsair has a 340kv motor. Did you transplant the FMS 360kv motor into it? I fly my FW Corsair with the stock motor and ESC but I'm using the FMS V2 Corsair 4-blade prop. I find it flies quite well, perhaps marginally faster than the FMS Corsair with the 360kv motor. I'm going to experiment with my FMS with the newer V3 prop hub and V3 blades, then with V3 prop hub, V2 blades and 8s on the HV ESC as per RC Informer.Hugh "Wildman" Wiedman
- Likes 3
Hey everyone. Got this far yesterday with my Corsair. I used a Home Depot paint code I found on this thread for the intermediate blue. Thanks to whoever it was that did that research, I think it looks just about right. Sent a request off to Callie this morning for decals. I’m going to try not to go crazy with weathering etc. This should be a fun one!
- Likes 5
Originally posted by EA-6B Geek View PostHey everyone. Got this far yesterday with my Corsair. This should be a fun one!I solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
Originally posted by Elbee View Post
E6, Looks like the perfect canvas, Sir. Which livery did you choose? Any mods in mind? Looking forward to seeing your progress. Best, LB
EA-6B Geek, Great livery choice. I like it. Best, LBI solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
Something for us f4u nuts... and since the dumb Aussie doesn't no how to put a link here yet !,, I will tell u it only new on u tube blancolirio will find it on u tube
Restoration of what will be the only airworthy birdcage corsair at vultures row aviation California very very cool enjoy go
- Likes 2
Just picked up the FlightLine Corsair 1600 from another club member. He's a 3D guy and tried a Warbird but didn't like it. Only has a dozen flights on it. Everything works as it should. However, the left main gear stutters as it comes down. Retraction is smooth. Right main gear is smooth both ways. He couldn't figure it out and neither can I. Any ideas?
Originally posted by ICM View PostJust picked up the FlightLine Corsair 1600 from another club member. He's a 3D guy and tried a Warbird but didn't like it. Only has a dozen flights on it. Everything works as it should. However, the left main gear stutters as it comes down. Retraction is smooth. Right main gear is smooth both ways. He couldn't figure it out and neither can I. Any ideas?
Originally posted by AZFlyer View PostHey everyone,
Any recommendations for an upgraded motor for this plane? I love the way it flies, but really looking for some more power. Any motor/mount/prop shaft combos that work and you recommend?
Thanks,
Originally posted by AZFlyer View PostHey everyone, Any recommendations for an upgraded motor for this plane? I love the way it flies, but really looking for some more power. Any motor/mount/prop shaft combos that work and you recommend?Thanks,I solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
Originally posted by xviper View PostTake it out and examine it closely for any cracks in the plastic housing or any dirt or crud in the parts that move.
For Flaps - you don't need any flaps for takeoff, it takes off very smartly and you usually have to hold it down because it has a tendency to take off before you're ready. For landing, you can use full deflection, as far down as mechanically possible. At that position you don't need to program any elevator trim because the flaps are generating drag, not lift. (Of course you need to land with at least 30% throttle to overcome that drag). I am using a tiny bit of down elevator trim because I found that it stopped the bounce, that's what worked for me,Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
