Originally posted by Elbee
View Post
Originally posted by xviper View PostThat's happened to several of my retracts on different planes, mostly very heavy, fast landing planes. It takes a very hard impact with something to do that. I highly doubt that just taxiing on bumpy grass will do it.
Quick question: I’ve just received brand new - the prop shaft has a tilt to the left, came this way.
Not sure if designed like this or production error?
And if I fly with this tilt if it is a production error will it pull my plane to the left?
when prop is on the tilt is quite significant
appreciate any help.
thanks
fin2 Photos
thats right thrust to combat p factor (torque) all is goodPlatt: fw190d9 Dynaflite:PT-19 IMP:Macchi202 ESM:fw190 ESM:Tank, Hien Jackson:DH-2 BH:macchi200 Extr:fw190 Holman:me109F H9spit2 FL:F4u,spit 9 FW:me262 GP:us60, Stuka, cub, F4u PZ:me109, albi EF Hurri, T-28 FMS: 2x fw190, me109 Lone Star:Skat Kat RSCombat:2xfw190d9
- Likes 2
Originally posted by Denniswpb View Post
Quite honestly, I'm really getting disgusted (pissed is more like it) with these flimsy cheap retracts! I've replaced several of them, and seems unless you make a perfect 9 or 10 landing, you will be ordering a new retract. Maybe that's why they are out of stock!. I've torn these apart more times than I can count, and it seems like the cam, trunnion, and worm screw are made from cheap Chinese pot metal. The plastic case needs to be a bit stronger also because they all crack just like in the picture. I've had other experienced warbird flyers at my club watch my landings, which may not have been picture perfect, but still pretty good, and they couldn't believe the retract could not handle it. Taking the left one apart again this afternoon... pretty pissed.
Anyone know if the standalone retract units are going to be back in stock any time soon???
Originally posted by GooberRC View Post
Unfortunately I'm right there with you. I'm so so close to just ditching this bird due to how often the retracts break. Now they are out of stock and my only option is to purchase a complete landing gear part. IF I repair this plane again it will almost certainly be the last time.
Anyone know if the standalone retract units are going to be back in stock any time soon???Hugh "Wildman" Wiedman
- Likes 2
Originally posted by Denniswpb View PostJust wondering if these FMS retracts will work. Anything is better that the cheap Flightline ones!
Originally posted by fin121 View PostHello,
I’m currently setting up my Corsair with a Futaba T6K receiver (instructions all German)
ive set everything up as I think it should be and when I power up it just keeps beeping - does anyone have any ideas what this may be because of?
Originally posted by Hugh Wiedman View Post
Hate to say this, but it's all in the landing technique. If you try to "flop" it in with some kind of a three point landing, they will break. Virtually every other warbird, like the P-51 or Spitfire, the gear can take a flopped in landing, but not the Corsair. All the landing pressure is directly on the worm screw alone since the retracts rotate. The only way you can land this one is with speed on a perfectly level orientation with just the 2 mains softly touching and then let in slow down and settle on the tail. I come in with full flaps, and only reduce the throttle to just under 40% and inch it down until the mains are on the ground, then reduce throttle to zero. When I first got this plane, I must have crushed about 5 or 6 retracts trying to flop it in or do a 3 pointer (or with just some fairly crappy landings). Since "learning" how to land it "scale" like, not a single issue with the retracts with over 125 flights and counting.
I also agree with Hugh about getting proficient with these taildragger warbirds to land in a two-point, tail low attitude, as their big brothers did. And when I have flopped one on in a three-point, usually some sort of damage occurred. Did that last night with my Freewing P-47D, where I got an unexpected bounce on a two point landing, tried to salvage the landing with a three point, and loosened up the plastic mount on one of the main landing gear. Was able to squeeze some Gorilla glue in there and clamp it, and I think it will be ok. But the planes I do have like the P-47, a 1600mm Spitfire, the Corsair, and an E-Flite P-51D, I have learned to get pretty consistent with the wheel landings to try and save the retracts. But it doesn't always work, and I end up having to replace them, too. I wish they were a stronger material, too, but I don't see any design changes coming up for them anytime soon.
Cheers
davegee
Hi Guys,
im having a difficult time linking my receiver to my transmitter. I have a Futaba T6K controller and R3006SB receiver
Could anyone give me some advice on:
- what connection I need to connect battery to receiver to power it?
any other things I need to know to get it linked?
thanks3 Photos
The battery connects to the reciever through the esc in the plane. Do not connect a 22 volt battery directly to the reciever or you will absolutely blow it. The esc has a voltage regulator that only allows 5-6 volts to pass to the reciever for power. If you want to power the reciever outside the plane you need a li-fe 6.6 volt or a nimh 4.8-6volt pack that can plug into any servo port on the reciever.
thanks
- Turn on the transmitter….should be close to the receiver (close helps the binding process)
- Plug in the 5V ESC output into the receiver any unused site
(see photo below…captured from the Internet). I use it! Then connect the ESC to your 22V battery
- With a plastic tool, Press the SW (down in the hole) for more than ONE SECOND to start the binding process
- Wait for receiver LED to turn steady green
On all my birds, I have had to reverse the throttle in the transmitter programming to make the motors work.
IMPORTANT!!! Calibrate your ESC after binding. You can Google how to or come back here. REMOVE THE PROP FIRST or risk injury.
Cheers,
GG
- Likes 2
Grossman56Team Gross!
