Official Black Horse Heinkel He-111 1750mm ARF Discussion Thread
  • Official Black Horse Heinkel He-111 1750mm ARF Discussion Thread
    Product page: https://www.motionrc.com/products/bl...111-1750mm-arf
    Designed in 1934 to get around the restrictions imposed by the Treaty of Versailles on military aircraft production, the Heinkel He-111 was initially produced as a commercial airliner that could be quickly and cheaply converted for military use as a bomber.
    The He-111 served with the Luftwaffe throughout WW2, serving on all fronts and in a variety of roles as well as the bomber role synonymous with the type. After WW2, it was adopted by Spain as the CASA 2.111 with whom it served until 1973.
    The model is scaled to approximately 1:13 and attention was paid to a true to original appearance and best flight characteristics. The model was designed for electric drives but can also be flown using a matched pair of internal combustion engines of about 4.5cc displacement.
    • Lightweight, strong, and fully sheeted laser cut balsa and plywood construction
    • Covered in high quality Oracover
    • Heavy-duty hinges on all control surfaces
    • Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
    • Painted and detailed dummy radial engine, cockpit and interior included
    • Fiberglass control horns with ball link connector
    • Comprehensive control and fitting accessories included
    • Two-piece, plug-in wings simplify transportation and assembly.
    • Fiberglass cowl
    • Fully illustrated instruction manual included and also available for download (see tab above)
    • Black Horse Heinkel He-111 1750mm (68.9") Wingspan - ARF
    Requires:Click image for larger version  Name:	he-111 updated.jpg Views:	0 Size:	75.8 KB ID:	194502
    Very interesting. Balsa though, hmmm!
    Bob
      Bob
      Worth it, Bob! It's just a bigger FlightLine P-38.
        Alpha, you know me all too well!
          The cowlings of the He-111 are molded from a single fiberglass mold, complete with recessed panel lines and raised rivets. Anyone who knows anything about molding knows that's quite an intricate feat. Here's a couple photos I snapped at the factory to show their craftsmanship. I really respect the old school techniques.
            OK, Ordered. I need another project like I need a hole in my head. But... It is a bomber!!!!
            Bob
              But these are the GOOD kinds of holes in your head! LOL
                True enough! Looking forward to seeing this one on my build table soon.
                Now, where are those Mitsubishi Betty's???
                  Thanks for these pics, Alpha!
                    Designed in 1934 to get around the restrictions imposed by the Treaty of Versailles on military aircraft production, the Heinkel He111 was initially produced as a commercial airliner that could be quickly and cheaply converted for military use as a bomber.
                    The He111 served with the Luftwaffe throughout WW2, serving on all fronts and in a variety of roles as well as the bomber role synonymous with the type. After WW2, it was adopted by Spain as the CASA 2.111 with whom it served until 1973.
                    • Fiberglass cowl
                    • Black Horse Heinkel He111 1750mm (68.9") Wingspan - ARF
                    quick question just crossed my mind.
                    https://www.motionrc.com/products/xw...tronic-retract
                    are these retracts specificly catered for the he-111 kit? meaning are they direct drop in fit with struts included and fitted with the wheels that come with the arf kit? or is there some additional work involved, which then would make one ponder about alternatives which they might already have in the hangar...
                    FAILURES ARE ONLY UNDERDEVELOPED SUCCESSES
                    https://www.pinterest.com/tengarang/edf-warbirds
                      It is my understanding that those retracts will be a drop in fit for this He111, yes. But don't kill the messenger, I'm just MRC's pixel pusher. ;)
                      I would ask Alpha or Stuart who would be in better position to answer definitively.
                        Off the top of my head, 10-15 size retracts work but I'd use 25 sized or even slightly larger, something like what the F7F Tigercat or Freewing 80mm A-10 uses. The plywood mounting plates aren't predrilled for a specific model/brand of electric retract so there's lots of versatility in selecting the exact retract unit to use based on your preference as long as it can handle the weight. Fixed gear is an option, too, although I'd make Tigercat main retracts fit if I planned on flying the He-111 as a daily driver.
                        • #13
                          Hi Guys, I'm in Europe so have just got up, good to see plenty of chatter though.
                          Regarding the RM400-90 retracts, they are intended for use with the He-111 and PC-9 (as well as future BH offerings.....;)) and should fit with very little modification, if any required. The strut supplied with the He-111 can be seen in the manual, screen grab attached (can be downloaded from our site also). Its not a full scale unit, but is an oleo so is a great place to start to get you flying. The RM400-90 does not come with a wire strut, simply a retract unit.
                          Hope this helps.
                          S.
Name:	Screenshot 2019-05-16 at 06.21.38.png
ID:	194613Click image for larger version
Name:	Screenshot 2019-05-16 at 06.22.12.png
                          • #14
                            Just when I thought I was lost, a cure for the jet kool-aid I've been drinking all year...
                            • #15
                              a pair of these:
                              https://hobbyking.com/en_us/propdriv...ner-motor.html
                              would really do it proud.
                              Joe
                              • #16
                                Alpha, the only thing that bothers me are the main gear struts. The he-111 had struts more like a Mosquito, Lancaster or DC-3. After market struts are hard to find
                                • #17
                                  I am finding it harder and harder to resist pushing that crazy order button!
                                  • #18
                                    Come on, you know you want to. :Devil:
                                    • #19
                                      As the Borg have often stated "resistance is futile".....:)
                                      • #20
                                        Does anyone know if the decals are preapplied?
